Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Transient heat flow
Old   June 1, 2011, 13:17
Default Transient heat flow
saisanthoshm88 is on a distinguished road
I'm totally new to electronics cooling and transient simulations. I had a newbie question. I was simulating the air flow inside a power amplifier cabinet which had Fans, Power sources and power amplifiers inside.
The power emanation from the amplifiers is of a transient nature and is described by the following details:
Output Power = 200 W
Duty cycle: Transient attribute:Gaussian, Total pulse duration: 6400 ms
So I see that I need to consider 6400 ms as the total time with a time step of 400 ms. But this is something relevant to a single duty cycle so will it be fine to analyze the heat flow inside the cabinet just for a single duty cycle on these lines.
Can some one please suggest me regarding this.
Best regards,
Santhosh.
saisanthoshm88 is offline   Reply With Quote
Old   June 7, 2011, 06:22
Disabled
Boris_M will become famous soon enough
Hi Santhosh,
First I wouldn't define 400ms time steps as your calculation would only have 16 Iterations which is way too short to get a flow or temperature distribution in your model. The time step should be the size to resolve what is happening in the flow. So I would suggest at least around 10ms. That way you have 640 iterations for one cycle. You can monitor the parts heat flux in a volume goal and should see how rough the steps between the iterations are. That way you would understand that 400ms is far to coarse.
Then if you run only one cycle your whole model is most certainly not reached any developed state as it would be as if the model would run for several hours. One thing you could do is run a steady state analysis to get the general flow field converged and use these results for a following transient calculation. You should therfore use an effective averaged value of your heat source as the steady state would be not for the full power of 200W.
When you've done that steady state project, simply clone the project and make the changes for the transient project. If you then go into the general settings you can select "transfered" instead "user defined" in the top row of the initial condition settings and link it to the staedy state project. That way it uses the staedy state flow as the initial flow for the transient and the amount of overall cylces would be much less than if you would calculate just transient. So instead of running 200 cycles you could try just 10-20 and see if the flow field in general changes any further in it's peak values. It should look like starting from a constant value (the steady state value) and then start to oszillate as you run through your min and max values of your heat source cycles and at some point these min and max values shouldn't change any more, somthing similar to the image attached. It is best to deactivate the maximum time and just let it run so you can abort it when you think it's fine.
I hope this helps,
Boris
Boris_M is offline   Reply With Quote
Old   June 7, 2011, 09:45
Many thanks for the suggestions Boris. Could you please tell me how to calculate the effective averaged value of the heat source for the steady state.
I really apologize for asking such newbie question but as I mentioned it i'm really new to this so your suggestions can certainly help me learn better.
Best regards,
Santhosh.
Old   June 7, 2011, 10:13
Disabled
Ups, sorry bad translation. It is the RMS (Root Mean Square) value.
Boris
transient result in spray reactor with swirl flow glenn creten Main CFD Forum 1 August 14, 2012 06:10
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Heat Transfer boundary conditions for engine coolant flow simulation rajuks Main CFD Forum 0 February 15, 2010 10:04
Flow around pipes - heat transfer coefficient on the wall of pipe doodek Main CFD Forum 2 November 23, 2009 09:48
time averaged heat transfer in oscillating flow Matthieu Ubas Main CFD Forum 2 November 5, 1999 15:20
