Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
FloWorks Airfoil Info
Old   February 22, 2010, 10:58
Default FloWorks Airfoil Info
Trev Burley
trvo is on a distinguished road
Hi All,
I'm new here and after a bit of help with some CFD on an airfoil I'm working on for a friend. Understanding the results is no problem for me and my friend, but getting the results is proving difficult.
The situation is that I have a completed 3d model of the airfoil in Solidworks and I want to use FloWorks to analyse the airfoil.
My current understanding is that I need to physically create a model wind tunnel, put my airfoil inside it, seal the ends and then apply FloWorks to it. Is this method correct or am I missing something?
My experience with Solidworks is limited to modelling components and surfaces and stress testing them so please forgive my lack of knowledge in the CFD area.
Many Thanks - Trev
trvo is offline   Reply With Quote
Old   March 3, 2010, 21:47
MuratSuer is on a distinguished road
Originally Posted by trvo View Post
Hi All,
Many Thanks - Trev
With CFD Softwares you can not get results as wind tunnel approach so it is not necessary to model wind tunnel Each wind tunnel has different characteristic depends on roughness(it occurs different bounday layer), nozzle or diffusour
For solving aerodynamic or hydrodynamic problems you should use EXTERNAL analysis option in Floefd while setting up FloEFD How to set up FloEFD you should use Wizard button in Flow Analysis Section
How to create boundary conditions? If you set up FloEFD with using Wizard you will see Intial Conditions region At this region you should enter the value of velocity freestream or Mach number depends on Cartesian Coordinate After setting up, you can run the analysis( For aerodynamic analysis your result resolution level should be upper from 6 level(7 or 8)
That's all and Have a fun
MuratSuer is offline   Reply With Quote
Old   March 4, 2010, 09:02
Trev Burley
Thanks MuratSuer, this will help me a lot. I will have a look into FloEFD.
Kind Regards - Trev
Low Speed Airfoil Mancusi FLUENT 7 April 3, 2014 07:11
Modeling Backflow for a 3D Airfoil (Wing of Finite Span) Josh CFX 9 August 18, 2009 12:31
Airfoil boundary condition Frank Main CFD Forum 1 April 21, 2008 19:36
OpenFOAM with Cygwin kitchener OpenFOAM Installation 6 April 25, 2006 00:09
COSMOS FLOWORKS Info Jordan Wright Main CFD Forum 0 November 30, 2004 16:22
