Rep Power: 17 ![]() |
I've been working with a model which contains a fluid volume. I've done several simulations with this model successfully. Now I seem to have a nasty problem after I changed one component in the assembly.
The component I changed (different config of the component) made the internal fluid volume somewhat larger. The fluid volume is still enclosed with solids. FloEFD gives rebuild errors and my "water in" and "water out" boundary conditions are not valid anymore. When I go to the "check geometry" window in FloEFD and try to find the fluid volume I get the following error: "Boolean operations failed. Please check your model." I really can't figure out what went wrong. When I change the component back to its original form FloEFD will still give me all these errors! Does this sound familiar to someone? Any feedback is appreciated. |
Rep Power: 16 ![]() |
When you did the "Check Geometry",
did you have the "Check for invalid contacts" checkbox activated? Are there any invalid contacts? Do you have a very complex geometry? Sometimes this makes problems. If it is so I export the model to step and then reimport it. This often works for me. Are you sure your modell is really closed? Did you check it by subtracting your model from a large Solid. Sometimes there are very small holes, where you do not expect them to be. |
Thanks for your reply. There were no invalid contacts. I decided to build up my model from scratch again. I got the same problem and I started suppressing parts one by one. I now finally got it to work. It turned out that the "auto generated lids" on the water in and output were causing the problem
![]() I still can't figure out what went wrong because the lids did close the volume and I did some simulations with these lids before. But this is a work-around I can live with. |
Christopher Ring
Rep Power: 0 ![]() |
The geometry error may be caused by the inlet/outlet feature and its respective lid feature having concentric surfaces of exactly the same radius. I have experienced the same problem in the past and, in working with the folks at Flomerics, resolved the issue by creating a small difference in the radius values. My suggestion is to create a slight interference. A small gap may force the mesh unnecessarily tight - depending on your settings - to capture the fluid flow in the narrow space created.
Hope this is of some use in your problem. |
Disabled
Rep Power: 24 ![]() |
It can happen if some parts of the model are not totally constrained or fixed in space that they were moved accidently somehow when clicking on it with still moving mouse or so. Usually the lids work just fine except the hole of the lid has no perpendicular depth to the surface. Imagine a hole that goes in on a slight angle.
A very good way is indeed the deactivating of the parts part by part to find the source. If it worked before and the surrounding of the lid didn't change it should work afterwards except as I said, it was moved. |
Archana
A detatiled "How to do CFD analysis in a butterfly valve ?" is what i am looking for..
It would be kind of you if you could help me... Thanks and regards Archana |
floefd, fluid volume, rebuild error |
There is no fluid volume in the project | Giron | FloEFD, FloWorks & FloTHERM | 5 | December 30, 2022 08:58 |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 00:58 |
problem with Volume of fluid in fluent | ash-khan | Main CFD Forum | 1 | March 13, 2011 02:22 |
Water vapour condensation in CFX-5.7.1 | hdj | CFX | 1 | November 27, 2005 07:15 |
fluid hot volume in fluid cold volume | zahid | FLUENT | 4 | June 1, 2002 09:11 |
