Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Need help with analysis of a small compressor/diffuser system
Old   September 27, 2009, 16:40
Default Need help with analysis of a small compressor/diffuser system
James Berlin
jkbg38 is on a distinguished road
Hello, I am doing my senior design capstone project on the optimization of the diffuser in a small turbojet engine that we are building. The compressor is 66mm diameter.
Because the diffuser is so small, lots of the diffusion takes place in the case rather than in the diffuser, so the case volume needs to be incorperated.
I am trying to start using some CFD on the current diffuser design and subsequently some new designs, but don't have the method correct yet.
I have gotten some results using an external flow with the rotating region around the compressor at 10,000rad/s, but I don't know how to add "backpressure" due to the combustion/turbine; I can only get results with the case open to atmospheric pressure. This, I think is leading to excessively high mach numbers and unuseable results.
When I try to use an internal flow analysis, I cannot select the lid at the exit because it is "not on the fluid boundary" and Im not sure why.
If anyone has advice or can suggest an alternative way of obtaining results I would appreciate it.
jkbg38 is offline   Reply With Quote
Old   September 27, 2009, 16:50
James Berlin
For reference, this is a cut away of our turbojet design and a rendering of the compressor and diffuser.
Old   October 1, 2009, 10:59
Algoa is on a distinguished road
Could you load a picture of your model with all parts visible and the computational domain. I don't quite understand where your lid is positioned. I had similar problems from changing an external calculation to an internal. Mostly I had to redesign the model and create a complete new file.
Algoa is offline   Reply With Quote
Old   October 3, 2009, 07:44
murat
murat is on a distinguished road
I suggest a code to redesign the project
http://www.softinway.com/
Axstream turbomachinery software has experimental solver and has CFD solver too
murat is offline   Reply With Quote
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
Parallel computer system for FLUENT analysis Jane FLUENT 4 December 4, 2008 02:26
Vibrating system analysis - a good introduction? Bren Main CFD Forum 0 November 20, 2007 13:40
Need ideas-fuel discharge system Jan FLUENT 1 October 11, 2006 00:05
Need ideas-fuel discharge system Jan CFX 1 October 9, 2006 09:16
