June 13, 2009, 12:45 |
Modeling blood flow - FloWorks
Dennis
Greetings - I'm involved in using FloWorks to model surface blood flows when the skin is exposed to high frequency thermal stimulation. My intent is to define the material of the containment vessels to reflect properties of arteries, veins, and capillaries ( thermal conductivity, thermal expansion coefficient, elastic modulus, and Poisson’s ratio), as well as defining the thermal conductivity of the skin and tissue immediately under it.
And now, the burning question Can I vary the pressure & flow rate to simulate blood flow by either linking to data contained in a spreadsheet or by using equations to relate those parameters to time? Thanks for any comments / thoughts - Dennis |
June 15, 2009, 05:02 |
Ivan Andronov
Rep Power: 17 |
Yes, you can use the Dependency option (see the f(x) button) to specify your parameters in a transient analysis both as a tabular or formula dependency on time. To enable transient analysis, select the Time-dependent check box at the Analysis Time step of the Wizard.
June 15, 2009, 12:53 |
Dennis
Thanks Ivan - I fished around for the dependency option you suggested (I'm still using 2008), and am beginning to sort out its use. Thanks again!!
blood, flow, pressure, thermal |
Multiphase flow (Eulerian) modeling | Umesh | FLUENT | 5 | December 29, 2014 10:06 |
Validation of blood flow code in a tube | vasilis | Main CFD Forum | 23 | May 5, 2009 06:52 |
Problems modeling subsonic engine air inlet with flow separation | TWaung | CFX | 2 | March 29, 2009 18:42 |
BLOOD FLOW MODELING (need help) | Keith | FLUENT | 3 | December 21, 2005 05:14 |
mold flow modeling | Pei Hsieh | Main CFD Forum | 0 | May 4, 2005 10:08 |
