Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Real Wall boundry cond
Old   June 12, 2009, 18:28
Default Real Wall boundry cond
Joshua Brickel
Joshua is on a distinguished road
I'm hoping someone can help me with a question I have about how Floworks handles its boundry condition called "Real Wall"
Basically it gives you 2 parameters to choose from:
1) Specifying the wall temperature
2) Specifying a heat transfer coefficient
but does not force you to take any choice. So what happens if you leave both conditions grayed out? When running the Wizard to set up the simulation it only asked for the outer walls Heat transfer coeff. But here I am using it for an internal wall. So I'm trying to figure out what sort of result I will get.
Thanks,
Joshua
Joshua is offline   Reply With Quote
Old   June 15, 2009, 06:20
Ive
Ivan Andronov
Ive is on a distinguished road
The wall temperature is defined during the calculation as a result of the heat exchange between fluid and solid. By specifying the Real wall boundary condition you can override this calculated temperature (or the heat transfer coef.) by your own value for the selected surfaces (walls). Of course, this may result in incorrect results or longer time for calculation to converge, so this choice depends on you and the reliability of the data you have. The Heat transef coef. for the outer walls will remain the same since you specify the Real wall condition for an internal wall.
Ive is offline   Reply With Quote
floworks real wall
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 16:33
how to hook this udf shanu FLUENT 1 August 26, 2011 11:48
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
udf error Rashmi FLUENT 0 December 27, 2005 06:35
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
