Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Fan Boundary conditions with external analysis
Old   February 6, 2009, 09:41
Default Fan Boundary conditions with external analysis
Rob
Hi all,
I am new to Floworks and have run through the various tutorials but I am having a real problem trying to run an analysis on my own models!
I have what is efectively a sheet metal chassis with an internal fan and lots of air vents. I was told by an expert during my training that I can run an external analysis and then not have to worry about creating boundary conditions for all my ventalation holes and also the main reason is that with sheet metal I don't have a true internal volume bacause of the way that the corners mate etc, ( lots of gaps etc). The problem is that I cannot add the fan because it tells me that it does not lie on a boundary regardless of whether I choose an internal or external fan. I have obviously created a seperate part for the fan which I have positioned into one of the sheet metal walls, as I normally do with an internal analysis. How can I get around this without having to suppress lots of vents and try to seal the chassis? I would really like to know because I cannot move forward until I know. Any help would be greatly appreciated. I have run several custom internal analysis without any problems, but when the chassis is very complex like this there must be a way to bypass building parts for boundary conditions.
Kind regards,
Rob
Old   February 10, 2009, 01:04
Default Re: Fan Boundary conditions with external analysis
M
Hi Rob
Do you set your analysis type as external? If yes, have you tried to use 'check geometry' to see if all the solids and the fan is picked up correctly?
In this case you can use an external fan, just make sure that you choose the correct faces for 'from fluid to fan' and 'from fan to fluid'.
Regards, M
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 07:49
Update boundary conditions calculated by an external program CedricVH OpenFOAM 2 January 15, 2010 12:55
Boundary conditions for rotating fan rohit Siemens 3 October 4, 2008 05:18
Boundary conditions for rotating fan rohit Fidelity CFD 3 September 24, 2008 08:18
Appropriate boundary conditions for external incompressible flow mattamos OpenFOAM Running, Solving & CFD 7 July 28, 2005 13:03
