November 25, 2008, 07:42 |
Torque defination
while defining surface goal of torque which surfaces should selected???
January 16, 2009, 16:21 |
Re: Torque defination
i want the defination of torque n the month when ssi report is done
February 18, 2009, 13:33 |
please i want detailed information on professional development workshops
February 26, 2009, 04:38 |
All the face that will ganerate torque in the direction should be selected.
February 26, 2009, 08:07 |
ok it means faces perpendicular to axis to rotation is not required to select as it will not produce torque..
jeremy, if you are pump user then tell from your experience how much diviation u found for torque or efficiency compared to tested one ? |
February 26, 2009, 22:00 |
Sorry ,I have no such data if you have a test data of a pump I can help you to simulate it.
March 4, 2009, 06:04 |
Re: Torque defination *NM*
Torque calculation of 2D VAWT Wind Turbine | Anonymized_JL1 | FLUENT | 14 | September 26, 2013 04:35 |
FloWorks torque bug? | PJC | FloEFD, FloWorks & FloTHERM | 0 | November 8, 2009 19:41 |
positive and negative torque forces | Wei-Haur Lam | CFX | 0 | March 19, 2008 08:45 |
Torque definition | Yali | CFX | 2 | January 7, 2008 04:13 |
about use macro to compute torque in TASCflow | lancy | CFX | 0 | June 10, 2003 07:19 |
