Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Parametric Study
Old   October 8, 2008, 11:42
Default Parametric Study
Murat
Hi All,
How to use parametric study tools?
For example,
I have an impeller.With parametric study I wanna analyze my impeller wing heigt between 5 mm-6mm to find best design.
How to do?
Thanks.
Old   October 13, 2008, 04:20
Default Re: Parametric Study
Ive
Start Parametric study.
Select Dimension. Click Next.
Select the Dimension defining the height of blades. Specify the minimum and maximum values. To select a sketch dimension, right-click the sketch in the FeatureManager and select Show. To select a feature dimension (like cut or extrude), right-click the Annotations item in the FeatureManager and select Show Feature Dimensions. Click Next.
Select the Goal for which you want to optimize your impeller (Volume flow rate, for example). You must have this goal already created. You can also specify the estimated minimum and maximum values of this goal. Click Next.
Specify the desired goal value. Instead of a constant value you can specify a dependency. Click Next.
Specify the convergency criterion - how much you allow the goal to oscillate to consider the solution as converged. Specify the maximum allowed number of calculations to achieve the desired goal value. You can also specify to create a separate configuration for each calculation. Click Next.
Check all the parameters and click Run.
LinkBacks (?)
LinkBack to this Thread: https://www.cfd-online.com/Forums/floefd-floworks-flotherm/27197-parametric-study.html
Posted By For Type Date
?????? This thread Refback February 4, 2015 08:56
Parametric Study - Multiple Configurations in ANSYS CFX kskong CFX 1 June 7, 2016 09:22
Grid Independency Study pchoopanya FLUENT 1 August 11, 2011 00:09
error problems between experimental and numerical study d118i Siemens 4 June 18, 2010 13:45
error problems between experimental and numerical study d118i Main CFD Forum 0 June 13, 2010 11:50
Study Mario Main CFD Forum 0 August 24, 2009 10:59
