September 23, 2008, 13:51 |
batch mode
I would like to study the same model with different flows at the entrance. Up to now I built different konfigurations with different flows each and solved these konfigurations individually. How can one do this in a better way, e.g. a batch mode, where calculation of the next konfiguration starts automatically. In this case I needed not to get up at two in the morning to start the next run. Since the flows differ not too much it would be desirable to use the result of one run as initial condition for the next run. Where to do theese settings? Thanks in advance and best regards Peter
October 2, 2008, 07:40 |
Re: batch mode
It is quite simple to load several case in batch mode since it is a build in feature of the code. You just have to go to the flow analysis/solve/Batch run menu and then select the cases you need to run. You have the same options there than in a direct run (create mesh, run solver,...) and you can choose the order of the run with the up and down buttons. I hope this will help you. Best regards Alain FRYDMAN |
October 6, 2008, 03:18 |
Re: batch mode
Thank you very much for your hint. I always thought, that the batch mode can only be used for processing the results. Best rgeards Peter Schaller
Running Ansys in BAtch Mode | kuleuvenstudent | ANSYS | 1 | October 18, 2017 12:11 |
to run a replayfile in batch mode from UNIX | froztbear | ANSYS Meshing & Geometry | 4 | May 13, 2014 08:00 |
cfdpost in batch mode | taichijulie | CFX | 1 | October 25, 2010 15:29 |
double precision for batch mode | Lawrence | STAR-CD | 2 | April 7, 2010 19:10 |
Prosurf in batch mode | Dhruv | Siemens | 1 | September 19, 2005 18:02 |
