Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
unsteady heating EFD.V5
Old   September 17, 2008, 08:19
Default unsteady heating EFD.V5
martin
Hi together, I want to simulate a gas flow wich heats a solid geometry in an oven from a beginning temperature up to a higher temperature with EFD.V5. Velocity is subsonic. I defined a volume floe rate at the inlet and an environment pressure at the outlet. I tried different Mesh settings up to 3 million cells. In every case the model crashed - either there is no error message and the solver closes automatically or I get a message that a problem has been detected and the solver needs to be closed, but no information where the error is caused. Does anyone simulate a similar problem and has an idea what I can try further?
Thanks and regards
Martin
Old   September 17, 2008, 11:21
Default Re: unsteady heating EFD.V5
Ive
First check that there are no big pressure drops at the start moment. To check this, try to load the r_000000.fld file which contains the initial flow and see the pressure distribution at the cut plot. The default pressure is the atmospheric pressure. If you specify additional thermodynamic parameters of the inlet flow, make sure that the pressure at the inlet do not differ too much from the initial pressure and the pressure at the outlet. Otherwise you must specify a gradient with Dependency. Also try to specify reasonably small time step. I this case you will probably need to use flow freezing to allow the solid to heat up. Any transient simulation requires some additional time and attention in comparison to a steady one.
Error with the unsteady flamelet Model Christoph_84 FLUENT 0 February 25, 2010 12:06
conditions for unsteady problems dvdromnu OpenFOAM Running, Solving & CFD 5 November 9, 2009 03:15
Unsteady simulation on the flow around Naca0012 Peter Pan Zhang FLUENT 2 June 11, 2006 20:53
Under relaxation factor for unsteady NS scheme? zonexo Main CFD Forum 0 September 26, 2005 22:15
steady or unsteady? (in dpm) winnie FLUENT 1 April 28, 2003 12:30
