Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
External Analysis with two fluid domains and heat transfer
Old   April 29, 2024, 21:56
Default External Analysis with two fluid domains and heat transfer
mariconeagles96 is on a distinguished road
Can floefd do an external analysis with two fluid subdomains as a cavity?
I am modelling a pump wherein I'm trying to cool the electronics inside a chamber or cavity of air. One side is cooling via water and the other side is cooling via air with natural convection where the my electronics cover is a heatsink.
So basically my analysis should be external with radiation, conduction, rotation (for pump impeller) and gravity for air cavity inside the electronics chamber.
Thanks a lot!
mariconeagles96 is offline   Reply With Quote
Old   May 8, 2024, 12:49
Christopher Schaefer
Javagonzo is on a distinguished road
Thanks a lot!
In brief, yes, that should be do-able. Each sub-domain/cavity can have it's own flow conditions as well as be a different specie from that of the main fluid participating in the external flow study. "Lids" will be required for the fluid sub-domains with water.
Javagonzo is offline   Reply With Quote
Old   May 9, 2024, 03:29
Thanks! I ran the simulation with no "lids" but just a close tube while place a surface on both inflow and outlfow so that I dont have leakage.
I got this error message;
"The inlet boundary condition may conflict with the supersonic flow regions at the inlet BC."
What seems to be the problem? I have defined my flow rate as LPM and outlet as Static pressure.
Old   June 18, 2024, 03:48
Kane Tracy
kanetracy is on a distinguished road
To sum up, I think that should be possible. In an external flow research, each sub-domain or cavity can have its own unique set of flow parameters and can be a different kind of fluid from the primary fluid. For the fluid subdomains containing water, "Lids" are necessary.
basketball stars
kanetracy is offline   Reply With Quote
Old   June 28, 2024, 04:36
Florian
native is on a distinguished road
Did you solve this meanwhile? I think supersonic flow is not reasonable here. Did you try with a reduced inlet flow rate? Maybe, could you share a screenshot or a sketch of your model setup?
native is offline   Reply With Quote
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Heat transfer between fluid-solid domains doesn't occur Gandin FLUENT 37 August 1, 2019 03:29
Heat transfer between solid rotating and stationary fluid domains DCSERE CFX 2 November 17, 2015 04:43
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 21:28
No Heat Transfer between two solid domains Mike ZH CFX 7 July 26, 2008 17:50
