August 1, 2023, 04:58 |
Floefd Autoclave Simulation
Berke
Rep Power: 3 |
Hello CFD-online forum,
I am reaching out to seek your assistance regarding a simulation I am conducting in the Floefd program. Specifically, I am attempting to simulate the autoclave and analyze the temperature variations of the air within it over time. To provide you with a better understanding of my progress, I have attached the relevant images showingcasing the data I have collected thus far. However, I am encountering a challenge due to the absence of heater data. Consequently, when I introduce a heat source into the system, the temperatures tend to escalate to exceedingly high levels. I kindly request your guidance on how to address this issue as I currently lack any data pertaining to heat sources. Your expertise and support in resolving this matter would be greatly appreciated. Thank you in advance for your assistance. I eagerly await your response. |
August 2, 2023, 12:21 |
Florian
Rep Power: 11 |
Hi Berke,
Some remarks and questions on your problem:
Florian |
August 2, 2023, 14:02 |
Berke
Rep Power: 3 |
Hello Florian,
Thank you for your response. 1- You are right, the temperature increase should occur due to heat sources, but since I don't have any technical data about the heaters, I cannot simulate a fixed heat source. 2- The pipes refer to the heater resistors. Since I don't have any technical data about the heaters, I cannot simulate a fixed heat source. Additionally, I'm planning a real-time analysis that will take 3 hours, so the air temperature will change over the 3-hour period. Let me explain with an example: In the first 20 minutes, the air temperature in the environment reaches 80 degrees Celsius, then it stays constant at 80 degrees Celsius for 1 hour. After that, it will reach 120 degrees Celsius, and it will stay constant for 30 minutes, and then the analysis will end. I'm providing these time frames as examples. 3- I understand that 15000W is quite high, but since I don't have any data, I chose that temperature just to test whether the other components of the system (fan, airflow, etc.) work properly. The main problem is the lack of data for a heat source. 4- As boundary conditions, there is an ideal wall on the inner side. There are no other boundary conditions. Since it is a closed volume, there is a fan inside. 5- As mentioned before, in the simulation, I want to achieve a temperature distribution as explained in point 2. It does reach 9000 degrees Celsius, and this is influenced by the 15000W heat input. However, as I mentioned, I don't have any data about the heat source. Therefore, I don't know how to proceed. Best regards, Berke |
August 3, 2023, 07:56 |
Florian
Rep Power: 11 |
OK, now I understand it a little better.
Florian Last edited by native; August 3, 2023 at 09:12. |
August 3, 2023, 08:12 |
Berke
Rep Power: 3 |
Thank you for the answer. I want to ask something else. I will try what you said. In addition, can we define a sensor in the FLOEFD program since we get the data from a point in real life and the hot air coming out of the heaters in the simulation affects the average air temperature? In this way, maybe I can evaluate the air temperature at the point where we measure the temperature in real life in the simulation and determine the heater power accordingly.
Best Regards Berke |
floefd |
Using results from simulation A in simulation B | Hafssa | FLUENT | 2 | October 9, 2022 04:19 |
FLOEFD API for heat pipe simulation | debuger | FloEFD, FloWorks & FloTHERM | 2 | August 16, 2017 10:25 |
Surface Source - Fixed Temperature? | robtheslob | FloEFD, FloWorks & FloTHERM | 18 | May 12, 2017 03:28 |
Simulation of high pressure diesel injector - all phases compressible with cavitation | fivos | CFX | 4 | July 30, 2015 07:48 |
Huge file sizes when Running VOF simulation | aarratia | FLUENT | 0 | May 8, 2014 13:27 |
