How to launch a sldasm file in foltherm using commandprompt |
August 18, 2022, 02:57 |
Naga KOTA
I am trying to parse the flotherm and sldasm file as arguments to command line and as well as i tried using the vb script to launch the flotherm to execute the file.
i tried with this code Sub main() Dim projName, filename, objFSO, prj projName = WScript.Arguments.Item(0) filename=TRIM(Split(projName,".")(0)) Set objFSO = CreateObject("Scripting.FileSystemObject") Set logger = objFSO.OpenTextFile(filename+".log", 2, True) Dim swApp Set swApp = CreateObject("SldWorks.Application") logger.WriteLine("Getting project name..."+projName) swApp.Visible = True Set proj = swApp.OpenFile(objFSO.GetAbsolutePathName(".")+""+ projName) 'Check Aplication Name was not empty or Not Null If proj.GetApplicationName<>"" Or proj.GetApplicationName<>Null Then logger.WriteLine("SW Launched Succesfully") End If swApp.ExitApp End Sub in the command line i am trying like this D:\sampleFiles >c:\Windows\System32\wscript.exe "C:\Users\Admin\Desktop\FloTherm\flotherm.vbs" cylinder2d.sldasm Could you please help with more details to solve. Last edited by naga.kota@ansys.com; August 19, 2022 at 10:15. |
2021, api script, flothermxt |
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 08:46 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
