Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
FLOEFD What if analysis
Old   August 5, 2022, 05:51
Default FLOEFD What if analysis
Kutay
yalandolan_cfd is on a distinguished road
Currently I am working on fin analysis in FLOEFD with NX 12. However when I filled all the input and output parameters and press the run button on the What if anlaysis, nothing will happen. Calculating notification is on at the bottom left but nothing wil calculated. Also, I couldn't change number of simultaneous runs at same time.
I can do analysis with same goals and get a result with basic run button.
I couldn't understand why that happens.
yalandolan_cfd is offline   Reply With Quote
Old   August 13, 2022, 09:04
DB
DB99 is on a distinguished road
On the Design Point or Scenario tab is Recalculate checked for each column what-if? Simultaneous runs requires additional solver licenses on another networked computer.
DB99 is offline   Reply With Quote
Force calculation in dynamic FloEFD analysis MaciekRyd FloEFD, FloWorks & FloTHERM 0 August 19, 2021 07:47
Urgent - Perform an DISCRETE adjoint analysis in parallel_computation JPBLourenco SU2 1 April 23, 2018 11:38
FloEFD: Flow through a nozzle and then into a domain Supriya_GM FloEFD, FloWorks & FloTHERM 2 April 19, 2017 02:19
FSI-system coupling: "...same analysis type"? rjw CFX 0 March 26, 2017 08:25
ANSYS WORKBENCH Transfer result of one analysis to a new analysis as preload ingjuanm90 ANSYS 0 July 26, 2016 15:04
