March 27, 2020, 14:09 |
Air with water analysis
Amir s
I have a tank with inlet and outlet port . the inlet port is higher than the oulet
i want to know if its possible to make a time dependent analysis. the original test that i want to simulate is: the initial condition is that the tank is full with air. at the beginning i fill water through the inlet port and after the water go above the oulet port i switch on a pump that keep the level of the water steady just above the outlet port. attached a file with the setup can i use floefd to simulate this test Regards |
April 3, 2020, 15:34 |
Yes, for FloEFD v17 and higher
Water Sphere reacting to flow of air modelling | Jacee | FLUENT | 0 | May 25, 2018 09:29 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Mass Transfer Between AIR and WATER | Math13570 | CFX | 12 | June 29, 2016 08:14 |
3D multiphase micro model: mixing effect of air and water at the T junction | ehsanfareed | FLUENT | 2 | March 22, 2015 22:29 |
Is it possible to integrate air through a system with mixture of air and water? | Hale | OpenFOAM Post-Processing | 1 | September 30, 2013 08:57 |
