Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Porous Medium Flow Simulation SolidWorks
Old   January 1, 2018, 01:42
Default Porous Medium Flow Simulation SolidWorks
Rishab M.
rishabm is on a distinguished road
I am trying to do flow simulation with air traveling through a heated porous medium and then through an insulated tube. Dome shaped piece is porous medium, frustum and the tube are insulated. I built the pieces using revolve, and tried to run the flow simulation but SolidWorks gives an error "There is no solid in the project. Please check geometry or component control." I am fairly new to SolidWorks and don't know how to proceed.Would greatly appreciate any help.
SolidPart and Error message attached.
Thanks
Rishab
rishabm is offline   Reply With Quote
Old   January 8, 2018, 06:27
Disabled
Boris_M will become famous soon enough
The problem is that you build a single body part and made the whole thing a porous medium. Basically, all you see is porous medium and you are applying an inlet onto a porous medium surface which is not an inlet but a porous medium.
It is best to either work with multi-body parts so the lid can be solid and the rest is a separate body which can then be the porous medium but then still the duct is also a porous medium and not just the top dome if that was the intention. The body is the smallest volume one can apply a volume boundary condition to it and if there is only one volume/body, then all of it will receive that condition.
Hope that helps,
Boris
Boris_M is offline   Reply With Quote
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
Flow Simulation : air around an rotating cylinder using Solidworks Flow Simulation Wyrold Main CFD Forum 0 October 22, 2015 09:48
Flow through porous medium using CFX: lack of convergence Chander CFX 3 July 23, 2014 07:32
Simulation of a complex wing in solidworks flow simulation niels1900 FloEFD, FloWorks & FloTHERM 6 April 20, 2011 11:44
Flow through porous medium Kiran AS Main CFD Forum 1 August 31, 2006 09:12
