March 13, 2017, 00:19 |
FloEFD API
Single
Dears,
Is there any way I can save cut plane or surface plot using FloEFD API. (I only find the way to get point value through API, but I want to save the plot pictures as output file.) Thanks. |
April 18, 2017, 06:40 |
Disabled
Rep Power: 24 |
Hi Single,
There is no direct way to specify a cut plane of surface plot as too many variables are necessary to define through the API. You should specify the plots when setting them up in FloEFD and with right click on them and using the "Save as" option you can specify what should the image be in terms of resolution and view angle etc. and if you do this for all the plots you want and specify in the batch results what plots should be created. The batch results can be done from the API as well. So once it is defined you can always run the batch results from the API and get the plots you defined. I hope this helps, Boris |
api, floefd |
Flotherm vs Flotherm XT vs FloEFD | zdunol | FloEFD, FloWorks & FloTHERM | 39 | July 14, 2020 08:36 |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 14:24 |
API in FloEFD for updating boundary conditions | Snow360 | FloEFD, FloWorks & FloTHERM | 1 | June 20, 2016 05:58 |
FloEFD for axial and radial blower | CmdrFALCO | FloEFD, FloWorks & FloTHERM | 3 | September 9, 2015 02:31 |
FloEFD API - SolidWorks Modeling | j.gerber | FloEFD, FloWorks & FloTHERM | 10 | December 7, 2010 21:14 |
