Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Turbocharger Compressor CFD Simulation
Old   September 28, 2016, 02:17
Default Turbocharger Compressor CFD Simulation
Mert
mertal1905 is on a distinguished road
Dear All,
I am quite new on CFD subjects.
I want to run both steady and unsteady turbocharger compressor simulation in FloEFD.
I have inlet pressure (static and total) values, mass flow rate and pressure ratio values. And I want to calculate compressor pressure ratio and compare with real value.
How can I define boundary conditions for steady and unsteady situations?
Will pressure inlet and mass flow outlet b.c.'s work?
Thanks in advance.
Mert
mertal1905 is offline   Reply With Quote
Old   October 11, 2016, 05:57
Disabled
Boris_M will become famous soon enough
Hi Mert,
Yes, you can do both steady state and transient simulations with FloEFD. For a real transient simulation in which you can see the fluctuations on the outlet you can use the sliding mesh simulation.
As for the boundary conditions, it depends on what you have as a boundary condition. If it is a transient fluctuation as an input then you can specify that to see the behavior of the turbocharger but if you only want to see how the rotation in transient might cause fluctuations in the pressure etc. then you can keep the BCs as a constant value.
The ideal setup in FloEFD is the mass or volume flow rate at the inlet and pressure at the outlet.
I hope this helped,
Boris
Boris_M is offline   Reply With Quote
Old   July 9, 2018, 15:43
Default compressor simulation
Shahzad
shezi266 is on a distinguished road
hello dear ,
can you please send me the turbocharger compressor data
shezi266 is offline   Reply With Quote
Old   July 10, 2018, 04:35
Disabled
Hello Shahzad,
Not sure what you are asking for.
Judging from your profile, you use CFX when looking at the other posts. So you are in the wrong part of the forum if you expect any help with your work in CFX.
Regards,
Boris
Waterbell Simulation o.b.m Fluent Multiphase 1 November 5, 2015 06:55
setting up a simulation with multiple interactions phandy OpenFOAM Running, Solving & CFD 1 October 6, 2014 04:16
mass flow rate issue in supersonic nozzle simulation xkang FLUENT 0 July 31, 2014 17:06
Simulation of a complex wing in solidworks flow simulation niels1900 FloEFD, FloWorks & FloTHERM 6 April 20, 2011 11:44
Continuous vs interrupted simulation sega OpenFOAM Running, Solving & CFD 4 November 3, 2008 15:29
