API in FloEFD for updating boundary conditions |
June 16, 2016, 05:49 |
Rep Power: 10 |
I have never worked with API's before. I am looking at writing an API to update a convective heat transfer coefficient and the fluid temperature after performing a simulation and then running it again. This would be an equation using goals from the previous simulation to update to the new b.c. This iteration would repeat until a certain tolerance is reached. I read on the help that this seems to be possible. However since I have never worked with API's I am having trouble starting. I looked at the example excel file and it looks like it doesn't do any iterative solutions. Also, how do I define both values for one boundary condition? If anyone can give me some tips or help that would be much appreciated! |
June 20, 2016, 05:58 |
Rep Power: 10 |
I am beginning to understand how to write this API through looking even more into the API. However I still have one question with the boundary condition.
I understand I can define the temperature and heat transfer coefficient with the nikParametersTypes_e. What are the propers ones to use here? For fluid temperature im guessing nikTemperature is right. But for the htc would nikSpecificSurfaceHeatGenerationRate be correct? |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 08:44 |
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source | silvan | CFX | 3 | June 16, 2014 09:49 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
