Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Heat sink problem in flotherm
Old   April 20, 2016, 01:41
Default Heat sink problem in flotherm
Sheraz
shanijo92 is on a distinguished road
Hi guys
I need to analyse the behavior of my switching PS pcb.the mosfets are getting extremely hot i need to design and investigate the temperature with heat sink.I am using S08 mosfet the related heat sink is FK 250 10 LF PAK.The export cad model is not transferring heat with the Mosfet.Heat transfer with the available library heat sink works fine.Any one suggest what i am doing wrong?
shanijo92 is offline   Reply With Quote
Old   April 20, 2016, 03:25
zduno
zdunol is on a distinguished road
idk, maybe check if you turned on heat conduction in solids, or if material attributes are correct? Also, which software are you using? If flotherm then check if geometry is aligned correctly, there might be a small air gap between two bodies resulting from incorrect conversion through mcad.
I hope it helps ;|
zdunol is offline   Reply With Quote
Old   November 2, 2016, 05:14
Melvin.
bighead is on a distinguished road
I think before using it in your model, create a simple heatsource with the heatsink on top and analyse the problem why it is not transferring heat, maybe like in a wind tunnel simulation. Once you find out the problem, you can change accordingly in your model.
bighead is offline   Reply With Quote
floefd, floworks & flotherm
Natural convection on a PCB's heat sink (with CFX) elcino CFX 10 July 3, 2014 13:03
Problem with snGrad() for heat flux. SKLee OpenFOAM Programming & Development 4 March 4, 2014 23:46
Help modeling heat sink aimee FLUENT 1 June 3, 2011 15:17
problem with heat flux in the wall gholamghar FLUENT 1 September 14, 2010 08:47
regarding B.C. of Heat transfer problem Manoj Padmakarrao Raut Siemens 0 March 17, 2005 01:01
