Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
FloEFD output variables
Old   February 12, 2016, 04:37
Default FloEFD output variables
Atze is on a distinguished road
Hi all,
Does anyone know if it is possible to define a variable to be plotted onto a surface in FloEFD? I'm using it inside CatiaV5 environment.
In particular I'm running simulations with humid air and I would like to plot the dew point based on temperature and abs. humidity.
Thank you all
Atze is offline   Reply With Quote
Old   February 12, 2016, 06:08
[SOLVED]
In "Engineering Database" there is a tab "Visualization Option" in which is possible to edit variables
Old   February 24, 2016, 04:11
Default PLease share
anonymous
Frakkel79 is on a distinguished road
I have also started to work with humid air. Can you please share a bit more ? I would really like to see how you set up the problem.
Regards
Jakob
Frakkel79 is offline   Reply With Quote
Old   March 30, 2016, 06:38
Originally Posted by Frakkel79 View Post
Regards
Jakob
Hi Jakob,
It's quite easy. You just need to set temperature, pressure and relative humidity (of course you have to pin "humidity" in fluid panel). It automatically calculate absolute humidity. This can be plotted trough the steam mass fraction variable
create, floefd, variable
FloEFD for axial and radial blower CmdrFALCO FloEFD, FloWorks & FloTHERM 3 September 9, 2015 03:31
Missing Output of debugwitch kflora OpenFOAM 0 March 13, 2013 12:33
Questions about data output aki_yafuji OpenFOAM Running, Solving & CFD 3 September 9, 2010 02:59
lift and drag on ship superstructures vaina74 OpenFOAM Running, Solving & CFD 3 June 8, 2010 13:30
How to obtain and output particle variables at certain locations zhaoxinyu Fluent UDF and Scheme Programming 2 April 28, 2010 21:00
