Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
"High Mach Number flow exists"--tho i m running the sim at 5m/s.
Old   August 13, 2018, 08:09
Default vortex problem
  #21
Shahzad
shezi266 is on a distinguished road
hello sir,
does this vortex problem affects the results?
thank you
shezi266 is offline   Reply With Quote
Old   August 13, 2018, 11:12
Disabled
Boris_M will become famous soon enough
Yes, that's why there is a warning.
Some result parameters might not be affected but others are.
For example, the pressure opening is defined with a specific pressure and temperature. That temperature is only valid if there is an inflow, then this temperature is used for the inflow. If you have heated air leaving the pressure opening but cooler air coming in through it due to the vortex in the opening, then the average air temperature at the opening will be lower as the vortex causes this issue.
Regards,
Boris
Boris_M is offline   Reply With Quote
Old   August 14, 2018, 04:02
Default supersonic flow problem
  #23
Shahzad
hello sir ,
you helped me alot sir in my project .
does supersonic flow problem depends on my boundary conditions ?
sometimes there is no this warning at some specific values as i am increasing flow rate or rpm ,this problem appears .
please suggest me how to get rid of this problem , as i think this is last problem which iam facing.
Thanks
Old   August 17, 2018, 10:01
Disabled
You don't need to worry about the high mach number option in your case. This is still good.
Reason is that the low compressible solver works good enough for a certain range over Mach 1-2.
Which method did you use, sliding or averaging?
Boris
Old   August 18, 2018, 01:25
Shahzad
hello sir ,
iam using averaging method
Old   August 30, 2018, 08:23
Disabled
Ok, then this should work just fine as it is.
Regards,
Boris
flow 3d, flow around a cylinder, flow over airfoil
decomposePar -allRegions stru OpenFOAM Pre-Processing 2 August 25, 2015 04:58
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library aylalisa OpenFOAM Installation 23 June 15, 2015 15:49
SigFpe when running ANY application in parallel Pj. OpenFOAM Running, Solving & CFD 3 April 23, 2015 15:53
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
Mach number and flow compressibility Guosheng Kang Main CFD Forum 5 October 26, 1999 16:56
