Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Flow simulation for an aerofoil
Old   April 22, 2015, 13:56
Question Flow simulation for an aerofoil
Anthony McCarthy
antm324 is on a distinguished road
Hi guys,
I been running SolidWorks flow simulations for a naca0012 aerofoil, generally the CL is quite accurate to experimental data, but then suddenly it under predicts the stall angle by 4 degrees
does anybody know the cause of this?
also the CD is over predicted, is this down to the amount of refinement on the boundary layers?, there is 3 refinement levels and the flow is laminar and turbulent.
the results are being converged for Fx and Fy
so far i have received a lot more accurate results using fluent, why is this the case?
many thanks
Anthony
antm324 is offline   Reply With Quote
Old   April 22, 2015, 18:49
Chris_321's Avatar
Christian
Chris_321 is on a distinguished road
can you make a picture of your mesh and domain?
Chris_321 is offline   Reply With Quote
Old   April 22, 2015, 19:06
Anthony McCarthy
unfortunately i am not a a PC with SolidWorks at the moment, and thus only have screenshots taken with none being of the actual mesh
I was thinking the problem could be down to the k-epsilon code not modelling boundary layer correctly?
Old   April 22, 2015, 19:19
Chris_321's Avatar
Christian
I had the same issues with FloEFD once, in my opinion the programm can not use the key advantages it has in simulations like that. But it should be possible to get closer to the experimental data.
Some things you could try:
Expand the domain in the wake of the airfoil, and shorten it in front of the profile a little bit. Maybe that can help.
You can try to improve your mesh even more with the manuel settings. For that turn of the "automatic" settings and improve the partial cells refinement.
Old   April 22, 2015, 19:25
Anthony McCarthy
my results at least for the Cl are not to bad apart from the stalling angle, and drag seems to be much worse. i was just interested to know the limitations of the software in external simulations. i have attached the results of these comparing them to experiemental data
Old   April 24, 2015, 05:55
Chris_321's Avatar
Christian
Try to improve your partial cells, they are very important for the boundary layer of the immersed boundary approach that floefd uses to calculate the values near the wall. You need to control your mesh by hand not with the automatic settings to do that.
Old   May 12, 2015, 13:27
fadli
genom92 is on a distinguished road
hey man, i'm currently doing the same thing as you. i'm doing the validation problem on naca0012 airfoil using solidworks.
your results seems better that mine though. can you attach the solidworks document. i would like to compare my setup and yours..
thanks..
genom92 is offline   Reply With Quote
Old   May 26, 2015, 14:19
Anthony McCarthy
Hey Fadli,
I do not wish to share files over the internet for the off-chance that these files could be found on turn-it in and have an effect on my grading for my dissertation. If you provide more in depth detail about your project and the options current chosen i would be happy to help.
Old   July 13, 2015, 10:04
Disabled
Boris_M will become famous soon enough
The Software can give much more accurate results if the mesh settings are right.
This was shown in a range of validations with many airfoils and full aircrafts such as from the Drag Prodiction Workshop.
Please send me your email address in a private message and I can send you a best practice guide in which there are also 3 validation models described.
Boris
Boris_M is offline   Reply With Quote
airfoil 2d, flow simulation, stall, turbulent
Fan simulation divergence ayothicfd CFX 18 July 20, 2012 06:53
Flow recirculation around a ducted fan Jane Main CFD Forum 2 January 24, 2012 06:17
Axial fan simulation in UG/NX 7.5 fan123 Main CFD Forum 2 April 23, 2011 09:22
axial flow in counter rotating ducted fan Vishu FLUENT 4 January 13, 2004 18:52
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
