Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Centrifugal pump simulation
Old   September 24, 2014, 02:37
Default Centrifugal pump simulation
Aibolat
Aibolat is on a distinguished road
Hi, everyone!
I am a new to Solidworks Flow Simulation. Me and my friend try to simulate the performance of centrifugal pump with casing. The radius of rotating region is 1 cm bigger than the radius of impeller.
The boundary conditions are:
static pressure outlet=107409 Pa
inlet volume flow rate = 0.5175 l/s
We also have experimental data. The pressure drop for numerical and experimental data is the same but the experimetal torque is 2 times larger. We also have a problem with outlet mass convergence. The value of friction fluctuates with amplitude of 50% from friction averge values.The criterion was set manually to the value of 5e-4 kg/s which is about 0.1% from total mass flow rate. What might be the cause? Any help is appreciated
Thank you in advance
Aibolat is offline   Reply With Quote
Convergence issues for a 3D Centrifugal pump simulation using ANSYS CFX enr_venkat CFX 7 August 31, 2016 19:58
CFD simulation of centrifugal pump cavitation billy7590 Fluent Multiphase 0 March 22, 2014 09:28
CFD simulation of centrifugal pump cavitation billy7590 Main CFD Forum 0 March 22, 2014 03:27
Assistance in Vacuum pump simulation enr_venkat CFX 5 November 20, 2012 12:50
SIG Turbo ERCOFTAC Centrifugal Pump - OF Revision Problem? marcelgt87 OpenFOAM 18 June 26, 2012 09:59
