Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
How to Calculate Porous Media A&B Constants
Old   April 23, 2014, 02:30
Default How to Calculate Porous Media A&B Constants
will321321 is on a distinguished road
Hi Gentlemen,
I am trying to simulate a simple duct work with perofrated plate and inorder to save calculation time I am trying to substitute the perforated plate with a porous media.
How do I calculate A & B inputs for porous media, A(kg/m^4) & B (kg/(sxm^3), with equation k=(A*V+B)/Density on the User Guide.
Questions:
1. Are A & B defined as the quadratic and linear resistance coeff. respectively?
2. What equation does FloEFD use for porous media? (is it DeltaP =- (inertial losses + Viscous losses)*Thickness)
Thank you in advance.
-will
will321321 is offline   Reply With Quote
Old   April 23, 2014, 04:24
SOHYEON MUN
SOHYEON MUN is on a distinguished road
Which CFD solver do you use to calculate it?
SOHYEON MUN is offline   Reply With Quote
Old   April 23, 2014, 05:27
Hello SOHYEON MUN,
Sorry for the incomplete information above, I am using FloEFD.
-will
Old   May 7, 2014, 07:23
Disabled
Boris_M will become famous soon enough
Hi Will,
1.
why do you want to use that model?
If you don't have any datasheet values that fir that model definition it will be more work that taking a small sample of the perforated plate in a seperate simulation where you run a range of flow rates and measure the pressure loss due to the perforated plate and use that then in the pressure loss vs. flow rate model of the porous media definition.
2.
It is part of the momentum and energy equation terms with the factor k you mentioned above. For more details please look into the documentation called "Technical References" that comes with the software.
But put simple, the loss of course relates to the thickness and area specified for a reference element and relates automatically then to the actual dimensions of the CAD model as EFD knows the dimensions etc.
I hope this helps,
Boris
Boris_M is offline   Reply With Quote
Old   May 20, 2014, 22:39
Hi Boris,
Thank you so much for the input, I have already figured out the relationship between A and B and DeltaP equation, using experimental data, plotting Velocity vs Pressure Drop and graphing it to obtain a second order polynomial curve.
-will
Multiphase Porous Media Flow - Convergence Issues VT_Bromley FLUENT 8 May 30, 2024 03:59
Porous media setup issues in Fluent Bernard Van FLUENT 29 January 26, 2017 05:09
How to model granular flow through porous media Axius FLUENT 2 August 7, 2014 11:34
species mass source in porous media ? PK FLUENT 0 February 16, 2007 12:12
porous media: Fluent or Star-CD? Igor Main CFD Forum 0 December 5, 2002 16:16
