Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
I want to confirm the performance of the axial flow fan.
Old   October 14, 2013, 20:57
Default I want to confirm the performance of the axial flow fan.
Korean Pie
Sanghyun - PARK is on a distinguished road
CFD calculation reference conditions of the axial fan.
Air, 20 [˚c] - 1.2 [kg/m^3]
Mass Flow = 16 [kg/s]
Static Pressure = 540 [Pa]
RPM = 1180 rpm = 123.569311 [rad/s]
------------Ansys---------------
In the case of Ansys Cfx program,
Inlet Lid = Total pressure - 0 [pa]
Outlet Lid = Mass Flow - 16 [kg/s]
------------Floworks---------------
However, in the case of a program of Floworks,
Inlet Lid = Mass Flow - 16 [kg/s]
Out Lid = Static Pressure - 540 [Pa]
Ansys program, satisfied with the results.
Floworks program are dissatisfied with the result.
Floworks conditions set, Is my mistake?
To answer please.
Sanghyun - PARK is offline   Reply With Quote
Old   October 29, 2013, 04:22
Disabled
Boris_M will become famous soon enough
I'm not quite sure I understood you correctly.
Is that the fan data in the engineering database? I hope there is more data of the mass flow rate for the fan to have a real fan curve that is depending on the pressure difference between the inlet and outlet of the fan. At the moment you have 16kg/s constant with some swirl, at least from what you wrote.
Also are you sure it is 540Pa? Is this a vacuum pump or a default fan such as for electronics cooling?
Other than that I cannot help you as there is too little information on what it not working right or what the error is that you see.
Regards,
Boris
Boris_M is offline   Reply With Quote
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 8 October 5, 2018 18:02
Review: Reversed flow CRT FLUENT 1 May 7, 2018 06:36
reg-Classical method of axial fan design ramamoorthyramanan Main CFD Forum 0 June 25, 2010 01:45
urgent pressure condition for axial flow fan VIPUL FLUENT 0 October 24, 2008 03:01
How to model flow of centrifugal fan? Peter Main CFD Forum 0 April 2, 2008 07:07
