Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Wall roughness effect on pressure drops
Old   March 13, 2013, 05:31
Default Wall roughness effect on pressure drops
Vangol is on a distinguished road
Dear All,
I'm trying to calculate pressure drops in a straight pipe with CFX 14.0.
I simulated two different cases with SST turbulence model:
- in the first case I set Wall Roughness = Smooth Wall on the solid boundary;
- in the second case I set Wall Roughness = Rough Wall (Sand Grain Roughness= 3mm).
In the Post-processing I evaluated the pressure drop for the two cases and it resulted perfectly the same. How it possible?
Thanks in advance.
Vangol is offline   Reply With Quote
Old   March 20, 2013, 05:50
Disabled
Boris_M will become famous soon enough
I think you sliped into the wrong part of the forum. You should try the Ansys part of the forum.
Boris
Boris_M is offline   Reply With Quote
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 01:04
wall roughness effect on pressure drop mactech001 CFX 16 February 22, 2013 06:55
pressure wall boundary condition in CFX murx CFX 4 October 9, 2012 07:50
Temp & Pressure jump at&near wall during iteration dokeun FLUENT 1 April 19, 2011 03:04
Wall function in adverse pressure gradients stephane baralon Main CFD Forum 11 September 2, 1999 05:05
