January 4, 2013, 04:15 |
Relationship of Surface Source and Radiation
WookJin Kim
Rep Power: 14 |
I wondering a function of Surface source.
Does the 'Surface Source' include Radiation effect? (Not the Environment, Solar radiation in General Setting) I make a heater and set the surface source as watt energy. And some wall is located a little way off heater. As a result, temperature of wall seems to be of no radiation effect. Please answer me.. |
January 4, 2013, 07:20 |
Disabled
Rep Power: 24 |
Hi Joseph,
if you consider radiation then the surface source will effect the radiation emitted by the body as you can define a heat source on the surface and with that a higher or lower temperature which causes radiation in some way. It should show an effect on the radiation as the body is heated due to the surface source but usually the better way in a heater is to define a voume source as usually not only the surface has the source but the whole body or the heater. But that can depend on the model and I don't know yours to tell you the best way to do it in your case. However, it is not directly a radiation source. But if you are using V11 or V12 already then you should be able to see also a "radiation source" feature where you can define a surface that emits a certain amout of radiation such as a solar opening etc. In case you have the HVAC or LED Module you can define a radiation source with a certain spectrum and also use wavelength dependent absorbtion etc. I hope this helps, Boris |
December 10, 2013, 00:44 |
WookJin Kim
Rep Power: 14 |
Thank you, Boris.
My message is too late, sorry. You're right, I understand. And I solve the problem the way that you said to me. |
3 boundary conditions at a time on a single wall surface | n7310889 | FLUENT | 2 | January 6, 2018 03:45 |
Radiation through: glass – air cavity – glass | Yingchun | CFX | 7 | February 27, 2012 17:46 |
Radiation on fluid-porous interface | DanR | CFX | 1 | November 26, 2008 11:28 |
radiation source-modeling people in room? | CFX5.7User | CFX | 0 | November 10, 2004 15:32 |
radiation source or heat flux BC? | pi | CFX | 4 | September 10, 2004 11:44 |
