Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Vertical axis wind turbine
Old   November 28, 2012, 19:32
Default Vertical axis wind turbine
colin
DrBidden is on a distinguished road
I am using a local rotating region around the impellor and axis which is transverse to the wind flow. The question is how large to make the diameter of the rotating region. There will be an error at the interface between wind direction and rotation. I thought that by making the diameter of the rr large then the error is further away from the impellor. However all that happens is you get a distinct rotating object ie the region and when you look at the velocity contours there is no continuity through the interface of the rr. I understand that if we were dealing with an axial (conventional) wind turbine then it is easier to define the rr. Any advice would be welcome.
DrBidden is offline   Reply With Quote
Old   December 18, 2012, 06:52
Disabled
Boris_M will become famous soon enough
Hi DrBidden,
Did I understand you correct?
You have an transverse fan where you want to have the fluid blown through it perpendicular to its rotating axis? So entering the RR on one side of the circumfernece and leaving it on the other side of the circumference?
This is a limitation of the RR and therefore not possible as the cicumverential velocity is averaged. This means that if we consider the flow going in x-direction through the fan it enters the fan with a relative velocity of for example +10m/s and exits it with -10m/s. This means it will average to 0m/s.
I hope this helps,
Boris
Boris_M is offline   Reply With Quote
Old   December 19, 2012, 20:03
Default Hi Boris
colin
Thanks for your reply. I am aware of the circumferential averaging hence the question about how best to set up the rotating region, in order to minimise error as much as possible. I currantly have aRR which is in the shape of an annulus so it only contains the vanes, and not the central region of the rotor. The alternative is to use a Global rotating option, but this has other problems associated with it.
Old   December 21, 2012, 04:45
Disabled
The problem with every RR is that is has cirumferential surfaces which are averaging the flow, no matter if anular or a full cylinder. There is no minimizing it for such cross flow, tangential or transverse fans. If you cannot use it as global rotating it will not give you correct results. I'm sorry.
Boris
Old   December 21, 2012, 21:50
Default Hi Boris
colin
Thanks for your reply. I will try to use the Global Rotation instead. Thanks for you help
High torque coefficient Cm for Vertical Axis Wind Turbine (VAWT) tony00 FLUENT 11 July 23, 2018 07:13
Vertical Axis Wind Turbine Rotating Domain Problems TWaung CFX 4 May 1, 2012 04:14
Reversed flow in Vertical axis wind turbine Anonymized_JL1 FLUENT 2 April 11, 2012 04:13
Vertical axis wind turbine in NUMECA ArslanOZCAN Fidelity CFD 2 July 21, 2011 06:04
3 bladed Vertical Axis Wind Turbine transient CFD ArslanOZCAN FLUENT 1 February 5, 2011 09:34
