Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Focused Radiation of a Xenon lamp (FloEFD)
Old   November 22, 2012, 05:46
Default Focused Radiation of a Xenon lamp (FloEFD)
karlos
Karim is on a distinguished road
Hey guys,
i want to simulate a solar radiation of xenon lamp in a head lamp without any heat sources. So to win the time i just took a small model with a housing, cover lens and a lamp (see the pictures). Iīve defined the radiation with an angle and a power of 100 W but without conduction and conductivity.
The computation has finished without any problems, in the post processing I canīt see any results (the scale is just blue).
When i try it again with a heat source, I could see the temperature distribution but without radiation.
where is the problem? can i compute a solar radiation with an angle without a heat source?
Thanks for your help
Karim
FloEFD 11 V5
Karim is offline   Reply With Quote
Old   November 22, 2012, 06:45
Disabled
Boris_M will become famous soon enough
Hi Karim,
if you didn't activate the heat conduction in the general settings then you shouldn't be able to consider radiation as this needs heat conduction to have an effect on anything.
Try activating heat conduction and radiation and then it should work. If you just use a heat source then the part is emitting heat with that power but without radiation since it was not activated so it will be just convection.
If you don't want any other parts have a conduction except the receiving plate of part of the radiation you can use Insolator as default material and specify the receiving part as any type of material you want to consider.
Boris
Boris_M is offline   Reply With Quote
Modeling both radiation and convection on surfaces - Ansys Transient Thermal R13 s.mishra ANSYS 0 March 31, 2012 05:12
Surface incident radiation Pipiola FLUENT 0 August 11, 2009 16:46
Multiphase radiation in CFX Luk_Fiz CFX 5 March 17, 2009 04:51
Radiation: definitions visatron CFX 7 January 8, 2004 16:25
Fluent incident radiation problem Michael Schwarz Main CFD Forum 0 October 21, 1999 06:56
