February 19, 2012, 13:20 |
Import CAD model
sajad
Rep Power: 16 |
I have a 3D cad model of an existing runner in CATIA (.igs extension) ,l want to do an optimization process on it with Numeca/Design 3D so i have to convert it to .geomturbo format , what's the easiest way to do it?
I tried to do it using "import IGES" & "import & link CAD" options in Autogrid , but it doesn't work, could you tell me what is the problem? and is there any other way to do it? thanks |
February 26, 2012, 00:26 |
Hamid Zoka
Rep Power: 19 |
"Geomturbo" format generates the blades through the points that define suction and pressure sides and also hub and shroud. So IGES or other formats based on lines and surfaces cannot be directly used to define geomturbo. Therefore you need some handy work in your 3D modeling software to exploit those points to generate your geomturbo file.
Regards |
February 26, 2012, 05:18 |
sajad
Rep Power: 16 |
thanks for your reply hamid
I think it's easier to "import and link" my cad geometry in autogrid and then export it to .geomturbo format, i have done it for simple geometries (for example 2D geometries of hub & shroud) . but now my problem is to import the 3D geometry of whole runner in autogrid . when I import it in autogrid it doesn't do anything, maybe there is some problem about my geometry? Regards |
March 2, 2012, 14:50 |
Hamid Zoka
Rep Power: 19 |
Maybe there is a problem with your geometry. normally autogrid accepts simple and basic shapes of blades. in case your model is sophisticated perhaps you need to simplify it. regards |
March 4, 2012, 06:08 |
#5 | |
sajad
Rep Power: 16 |
Hi I imported my geometry in autogrid finally. but now i have a lot of errors : "discontinuity" in hub & shroud or leading & trailing edge , leading edg or trailing edge "doesn't intersect" hub or shroud , "overlapping" ,etc! i am really confused! it seems that you are well familiar with this software , could i have your contact information for more help? (I am master student in elm o sanat university and i couldnt find anyone around that could help me on this software) Regards |
March 6, 2012, 00:07 |
Hamid Zoka
Rep Power: 19 |
May 2, 2012, 05:15 |
Ion
Rep Power: 16 |
August 2, 2013, 12:57 |
Chaithu
Rep Power: 13 |
Hi friends..
I have a similar problem but, I have .geomTurbo files and have to convert it to igs to generate the blade ? I am new to catia and donno how to go about it. Can someone please help me. Thanks a lot |
cad model, geomturbo, import, numeca |
Can Fluent Import New Turbulence Model By UDF? | Andy Cong | FLUENT | 4 | March 25, 2016 14:14 |
Centrifugal Pump CAD Model Required for validation | bhatiadinesh | CFX | 1 | June 25, 2013 05:16 |
How to import 2D wireframe model to GAMBIT | vrd | FLUENT | 0 | June 12, 2011 13:47 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 21:30 |
I-DEAS CAD data import with boundary conditions | Yunus | Siemens | 1 | June 1, 2001 11:04 |
