June 7, 2011, 18:11 |
Import 3D model in IGG
Chris of the Time
Rep Power: 15 |
I am wondering how can we import in IGG a 3D model built using AutoCAD. Also we have access to ANSYS Workbench if this could help. Which file formats can IGG import? I have already tested the .dwg file and the software couldn't import it.
June 7, 2011, 21:58 |
IGG is not accepting the .dwg format and in fact it only accept .iges, parasolid or CATIA V5 format only from external CAD. If you are working with turbomachinery set-up, you would need 2 surfaces representing the blade and 2 curves for the hub and shroud respectively. Regards CJ NUMIT Enterprise http://maccom-numit.blogspot.com http://www.numit.com.my Email : Seiko.Q@numit.com.my
Regards CJ NUMIT Enterprise, Malaysia +6 017 656 3436 http://maccom-numit.blogspot.com http://www.numit.com.my Email : seiko.q@numit.com.my |
June 8, 2011, 02:59 |
Chris of the Time
Rep Power: 15 |
Sir,
Thank you for the immediate answer. We don't own any of Parasolid and CATIA software. Is there any way to export the model with these extensions without the software? I would prefer not to be involved with NUMECA's designing IGG, because I am NOT familiar with it at all, but I can design 3D models in AutoCAD environment pretty well. Which are the file extensions that IGG can import? |
June 8, 2011, 03:14 |
Hi Christos,
I am not sure what you are looking for. But most of the external CAD can export to universal file extensions named parasolid or iges. These are preferred 2 file extensions to be accepted by IGG. In here, we only support NUMECA's design tools only. Perhaps you could describe your case in more details. CJ
June 8, 2011, 03:37 |
#5 | |
Chris of the Time
Rep Power: 15 |
[EDIT] AutoCAD unfortunately cannot export to both .parasolid and .iges |
June 8, 2011, 03:44 |
If i could imagine that you are designing a rotating blade (with current profile) and intended to optimize (future profile), i would recommend you to use NUMECA Autoblade(TM), the blade sketcher as well as parametric geometry for the optimization purpose. You may utilize FINE/Design3D for optimization purpose.
Could you be possible to describe with me what is the actual case study that you are working with?
June 8, 2011, 12:55 |
Chris of the Time
Rep Power: 15 |
Firstly I would like to thank you for the help! Also I have to make clear that I am very new to the NUMECA (and the whole computational analysis) environment and procedures, so excuse my mistakes and unfamiliarity. Sir, that what I am trying to do is to import a 3D model of cochlea (already constructed for our Hydraulics Lab and designed using AutoCAD) to NUMECA IGG, in order to practise on a "real" case, which is also the point of my work.
June 9, 2011, 22:33 |
Sure, let me know if you have further doubt. We are always here to help you to solve your problem.
June 10, 2011, 05:39 |
#9 |
Chris of the Time
Rep Power: 15 |
I have exported the 3D model (from .dwg to .igs) using ANSYS DesignModeller that has the option to export to this type of file. BUT when I am trying to import it to IGG, it shows nothing.
June 10, 2011, 05:43 |
#10 |
Could you send the .igs to my email below?
September 1, 2011, 16:04 |
#11 |
Rep Power: 17 |
IGS file works fine in IGG.
file extension, file format, igg, import |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
New implemented algebraic Reynolds stress model | volker | OpenFOAM | 13 | October 21, 2013 01:01 |
Import Fan 3D Model - Workbench or CFX? | Stewart Long | CFX | 2 | October 28, 2008 05:05 |
Import a 3d model (Solids 3d) from autoCad to Phoe | Anastasia | Phoenics | 4 | September 28, 2008 14:46 |
how to import the model from the gridgen | ztdep | Siemens | 1 | October 16, 2005 16:39 |
