Home > Forums > Software User Forums > Fidelity CFD
Vertical axis wind turbine in NUMECA
Old   May 12, 2011, 11:24
Default Vertical axis wind turbine in NUMECA
Arslan
ArslanOZCAN is on a distinguished road
I want to generate 2D and 3D mesh of a vertical axis wind turbine. NUMECA has good grid generator and solver for rotating devices. As it indicates in product website it solves vertical axis wind turbine, but i couldn't figure it out. Here is the link : http://www.numeca.com/index.php?id=440
Anybody knows which blade row type needs to be used ??????
ArslanOZCAN is offline   Reply With Quote
Old   June 5, 2011, 07:06
CJ
oldshoes81 is on a distinguished road
Send a message via MSN to oldshoes81 Send a message via Skype™ to oldshoes81
Hi Arslan,
We always refer to Z-axis if you are talking about the axis of rotation. The generation of mesh may take minutes only to reach more than a million of cells.
We prefer to use our NUMECA blade sketcher to generate the geometry. If i am not mistaken with your question, you are concerning about the mesh wizard in Autogrid(TM) 5 and thus you should refer to wind turbine template of course.
Regards
CJ
NUMIT Enterprise (Malaysia)
+6 017 656 3436
http://maccom-numit.blogspot.com
http://www.numit.com.my
skype : cjquah
oldshoes81 is offline   Reply With Quote
Old   July 21, 2011, 06:04
Lightbulb Vawt
sanboju
sanboju is on a distinguished road
Hi ArslanOZCAN,
For design a 2D VAWT (darrieus type-H), first of all, I recommend you to choose different airfoils from "Airfoil Investigation Database" and using XFLR5 set up the parameters of lift and drag for differents AoA and compare and improve or modify the geometry of the airfoil you finally choose; that's only useful if you want to design a giromill, because if you want to design a controlled-pitch angle VAWT you only have to define the optimus AoA to get higher lift with a defined profile.
Once you select the airfoil, you have to import it to IGG as Data file (you have to define a 2D project before this step) and duplicate and positioning the airfoil with the number of blades you need. The next step is define the blocks, the grid, boundary conditions, ...
I hope will be useful for you,
Greatings,
Sanboju
sanboju is offline   Reply With Quote
High torque coefficient Cm for Vertical Axis Wind Turbine (VAWT) tony00 FLUENT 11 July 23, 2018 07:13
Vertical axis wind turbine CFD Analysis Akhilesh FLUENT 4 April 13, 2012 17:44
Reversed flow in Vertical axis wind turbine Anonymized_JL1 FLUENT 2 April 11, 2012 04:13
3 bladed Vertical Axis Wind Turbine transient CFD ArslanOZCAN FLUENT 1 February 5, 2011 09:34
Vertical Axis Wind Turbine courtjester140 ANSYS 2 June 22, 2010 11:27
