November 2, 2010, 13:59 |
Other than Parasolid?
Rodrigo Medina
Rep Power: 16 |
Hi, I am just starting my Master Thesys and it involves the use of Numecas Fine/HEXA Software. At my curent university we do not have license for Parasolid to create the ground surfaces we want. Y would like to know witch other cad programs can I use that are compatible with Numecas Hexpress or what other options do I have to create my surfaces ant convert them to .x_t.
Thank you very much in advance. |
November 5, 2010, 08:57 |
Tutorials
Rodrigo Medina
Rep Power: 16 |
Can anyone tell me where I can find tutorials for Numeca Fine/Hexa?
November 5, 2010, 14:40 |
Romain
Rep Power: 17 |
On Numeca's website... if your university bought a license, they have access to the customer area.
November 8, 2010, 01:14 |
Hamid Zoka
Rep Power: 19 |
Dear Rodrigo;
Hexpress accepts .stl format as well. you can easily generate Parasolid or .stl files in 3D softwares such as "Unigraphics" and import them to Hexpress. does it help? regards |
November 11, 2010, 11:44 |
Rodrigo Medina
Rep Power: 16 |
Thank you Hamid.
Yes I did help. |
November 11, 2010, 11:59 |
Creating Control Volume
Rodrigo Medina
Rep Power: 16 |
In my recent proyect I´m trying to do a CFD analisys over surface of great extension. I can get the .stl of the surface map (Global Mapper) and import it to HEXPRESS to create a posible .dom. My problem now is that I have to create I control volume and thge surface alone does not count as a close control volume. I´ve been thinking on creating inside Hexpress (CAD manipulation) a box, transform this into a domain and finally import an internal surface (the .stl file from GM mentioned before). I´ve try it several times but I keep getting some error about some .bcs that the programm is not finding while trying to import the internal surface.
Does anybody have any ideas as to how can I create this control volume inside Hexpress or do you think it is better to create this volume in AUTOCAD or any other CAE programm. Thank you very much for your Help. Rodrigo |
January 24, 2011, 09:12 |
sanboju
Rep Power: 15 |
Hi Rodrigo,
Are you in a trouble of the box mesh? In the mesh wizard (initial mesh panel) you can choose how do you wanna your mesh will be. It computes the control volume. I'm not really sure of the problems you have when you import a solid model like *.stl. If you have problems with this extension you can try to import CATPart model from Catia V5. If you talk spanish you can send me a private message to understand better your trouble and I could try to solve the problem with HEXPRESS. Cheers |
Parasolid import in Gambit | Micheal | FLUENT | 1 | January 19, 2015 03:18 |
Parasolid Import Error | Alpro_Soya | STAR-CCM+ | 4 | February 10, 2010 09:58 |
Question about parasolid | sahar | Main CFD Forum | 1 | October 10, 2009 14:13 |
Importing file from Parasolid to ICEM | prateek jain | CFX | 0 | May 28, 2007 02:16 |
[Q] Exporting to igs or parasolid from a mesh file | Stefano | FLUENT | 1 | July 12, 2006 14:29 |
