Home > Forums > Software User Forums > Fidelity CFD
Weighted Deformation Mesh technique in Fine/Marine
Old   September 27, 2010, 18:32
Default Weighted Deformation Mesh technique in Fine/Marine
Naimish Harpal (MS Aerospace Engr)
naimishharpal is on a distinguished road
Hi all,
I am working on a DFBI project using NUMECA Fine/Marine software. Does anybody have any guidelines on how to use mesh deformation technique?
I will really help your suggestions and guidelines.
Thanking you,
Naimish Harpal
naimishharpal is offline   Reply With Quote
Old   September 28, 2010, 12:23
Romain
Rombzh is on a distinguished road
I have only used grid deformation for a two solved DOF (sink and trim) problem.
Usually a time step of Tref/200 and 4 iterations per time step is enough for resistance cases (I use quasi-static method + sub cycling). If the amplitude of motions is going to be more significant (like in waves), I would advise 8 to 10 iterations per time step.
Rombzh is offline   Reply With Quote
Old   September 28, 2010, 18:51
Default mutli-body DFBI
Hi Rombzh,
Thanks for the suggestions. I have already done this work, and the CFD results seem reasonable too. Now, the issue is to perform grid deformation when there are two boats placed close to each other. What could you suggest here?
Old   September 28, 2010, 18:59
Romain
Oh sorry I did not get that.
Well all I know is that you need to activate the grid deformation for all DOF, even if some are fixed (that's some guideline I've read once, or maybe it's just in the manual).
I've never done any of this before though and I do not remember reading anything about such a case done with Fine/Marine.
About time step matter, I don't think you would need to change anything.
Old   September 28, 2010, 19:26
I know what you are talking about. The manual/user-guide suggests to turn-on mesh deformation for all 6DOF for multi-body DFBI. Even though following the suggested guidelines, the solution diverges in couple of iterations. Anyways, now, I have simplified my problem by considering Laminar flow. Let's see whether its problem with turbulence model compatibility or mesh problem.
Old   September 28, 2010, 19:30
Romain
Do you end up with negative volumes ?
Old   October 13, 2010, 00:46
Hi Rombzh,
As you pointed out in previous conversation, I am ending with Negative volume problem with large deformation. I am planning to add Adaptive Mesh Refinement (AMR) on free surface to avoid negative volume. As my machine is out of order, I am off for this project for some time. Just waiting for to be fixed ASAP.
Anyways, do you have any suggestion and/or new recommendation to avoid negative volume problem?
Thanks.
Old   October 13, 2010, 11:14
Romain
I guess there is no magical answer for that kind of problems unfortunately.
I would say :
- try to increase the non-linear iteration number, till 10 for instance
- lower the time step (but this cannot really help at some point, if you have to use Tref/400...
- refine the mesh close to the geometries.
Old   December 11, 2010, 18:03
Hi Rombzh,
I am glad to tell you that the problem of negative volume cells is resolved now. We tried the case with improved mesh quality near the walls, and that worked.
Thank you very much for your valuable suggestions.
C u.
dfbi, weighted deformation mesh
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 01:27
Mesh deformation using user fortran matled CFX 3 February 18, 2010 17:49
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
CFX mesh deformation YY CFX 0 May 3, 2008 19:52
basic of mesh refinement arya CFX 4 June 19, 2007 13:21
