Home > Forums > Software User Forums > Fidelity CFD
urgent problem in the multi-stage multi-row computation
Old   September 18, 2010, 10:27
Default urgent problem in the multi-stage multi-row computation
BalanceChen is on a distinguished road
I generated the multi-row grid by copy and rotate an existed grid block. Thus the IGV have 8 channels and rotor have 24 channels. Then i connect them in IGG by "import IGG project". Next, the boundary condition is reset, i.e., the connecting face is set to be "ROT".
The problem is when i am going to run in fine turbo, after reading in the grid, errors go as
"CSTRDA/C1DMED: TOO MANY MERGER PAIRS( 41 > 40)
NBCMAX EXPERT PARAMETER SHOULD BE INCREASED"
I have no idea of what should i do, is there anybody come across problems like this, please help me, thx~~
BalanceChen is offline   Reply With Quote
Old   September 21, 2010, 00:14
Hamid Zoka
Hamidzoka is on a distinguished road
NBCMAX is an expert parameter that can be set in NUMECA.
when you change the fine/turbo mode from "standard" to "expert"
you can find it in one of tables of "contorl variables" page, namely"integer parameters".
but i think your problem is mainly due to number of channels you 've selected. why 8 and 24? perhaps this enormous amount of mesh causes such problem. if you are to solve an steady problem, just one blade per each row will be enough. but in case an unsteady solution is desired, the best solution is to choose the lowest integer balde count ratio. e.g. a configuration of 1 to 3 is adequate for this case. this will reduce your meshing to 1/8.
Regards
Hamidzoka is offline   Reply With Quote
Old   September 23, 2010, 22:26
Thank you very much for your detailed explanation, problem is figured out~
The problem i consern now is with an nonaxisymmetrical inlet flow, whole rows computation is thus needed.
Thanks again.
Regards.
Urgent problem - orthotropic material in ICEM Luk CFX 6 August 30, 2006 09:06
Valve seal problem! Urgent songxguan Main CFD Forum 0 May 11, 2006 23:04
Multiphase Problem (Urgent) Dadang CFX 4 June 21, 2004 08:46
a problem on convergence in stage interface feng CFX 0 January 29, 2004 12:01
Parallel computation problem in Tascflow dandy CFX 3 April 21, 2002 01:32
