Home > Forums > Software User Forums > Fidelity CFD
k and epsilon
Old   June 26, 2010, 05:36
Default k and epsilon
Hamed
safikhani_hamed is on a distinguished road
Dear all,
I want to model a centrifugal pump in NUMECA using k-eps turbulence model, how ever I just have intensity and length scale at inlet, how can I convert intensity and length scale to k and epsilon at inlet ?
sincerely
safikhani_hamed is offline   Reply With Quote
Old   June 30, 2010, 08:06
Hamid Zoka
Hamidzoka is on a distinguished road
Dear Hamed;
if pump inlet velocity is known, ( inlet velocity may be calculated by knowing pump flow rate and pump suction side diameter) you can find k from turbulence intensity relation.
calculated k can be applied to length scale relation to find epsilon.
does it help?
Hamidzoka is offline   Reply With Quote
Old   January 24, 2011, 09:44
Lightbulb
sanboju
sanboju is on a distinguished road
Hi Amed,
Sorry because the late answer.
As you know, k is the kinetic energy and epsilon is the disipation of turbulence. We could consider epsilon as 0.1*k. The kinetic energy k, can be calculated as: k=3/2 (T*U)^2, where T is the Temperature of the problem, and U is the inlet velocity.
I hope I'll be helpful.
Cheers
sanboju is offline   Reply With Quote
Old   January 26, 2011, 12:10
Exclamation Tu
sanboju
Sorry because of the definition of the other day. As you know in a turbulence model, the units for k are [m^2/s^2]. I was wrong saying T was the temperature of the model, T is is a percentatge that represents the turbulence intensity factor as I've seen on biography. I realise because of my job results, intensity of the turbulence and the poor disipation.
T = 0.05-0.10 (biography, fluctuations respecte wind velocity)
U= inlet velocity
Sorry if someone have run their jobs after my definition of k but I wouldn't get results yet.
k= 3/2(T*U)^2
epsilon = 0.1*k
Greatings,
sanboju
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 16 March 4, 2017 09:30
MRFSimpleFOAM goes divergenced! renyun0511 OpenFOAM Running, Solving & CFD 0 November 19, 2009 03:11
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 21:21
Unknown error sivakumar OpenFOAM Pre-Processing 9 September 9, 2008 13:53
Epsilon Convergence Trouble Carlos FLUENT 4 August 27, 2007 12:22
