Home > Forums > Software User Forums > Fidelity CFD
Mesh in Hexpress of Numeca
Old   April 5, 2010, 09:21
giacomo combariati
jackr84 is on a distinguished road
I have determinated my problem. I post a figure in that i show the problem. How can i eliminate this surface. For this motive i don't create the mesh.
jackr84 is offline   Reply With Quote
Old   April 5, 2010, 11:48
Romain
Rombzh is on a distinguished road
You seem to have overlapping surfaces, in that case I think you need to fix the CAD first, as Hexpress won't be helpful for this matter.
Rombzh is offline   Reply With Quote
Old   April 6, 2010, 15:52
giacomo combariati
I resolved the problem. Now I do the mesh of two volumes, but for the third volume when I try to do the optimization phase the process failed.I try to modificy the optimization level but the optimization don't finish.
Old   April 6, 2010, 15:59
Romain
Check in the log file what is happening. It should point an issue with a specific edge or face.
Old   April 6, 2010, 16:09
giacomo combariati
There are concave cells and negative cells. How can i reduce them?
Old   April 6, 2010, 16:30
Romain
check where exactly this is happening and create local refinements maybe.
Old   April 7, 2010, 10:17
giacomo combariati
I imported the mesh in Numeca,but when i set the boundary condition of inlet there is a problem:
Erros:Can't read "ith_bc(phys_var;min_value;StaticPressureExtrapola ted,24,1,6)":no such variable"
Old   June 5, 2010, 23:20
swaroop006 is on a distinguished road
hi "jackr84".......first of all check the boundary conditions-in HEXPRESS refinement is done on only on those surfaces which are tagged as WALL. Check the things out like geometry is clean & valid....if not try to clean in 3matic(no need of it, as you are saying that u were having x_t file; in hexpress itself u can clean), define proper taget cell size-TCS (TCS=initial_size/2^(refinement_level)), & hexpress has an built in algorithm which has success rate of 99.98% removing concave cells through default optimization step.
swaroop006 is offline   Reply With Quote
Old   December 21, 2012, 10:52
Default Hexpress
  #29
FSoares87 is on a distinguished road
I'm new with hexpress. Are there any tutorials?
Thanks in advance
FSoares87 is offline   Reply With Quote
Old   December 17, 2014, 02:50
Default Hexpress view 41
  #30
SAN
djsantoshkiran is on a distinguished road
Hello Everyone,
Am facing some difficulty with the configuration file (.conf)in
HEXPRESS VIEW41. Is there any one who is using the same software.
Being a beginner i couldn't get the solution for my problem .
Please do reply.
Regards,
DJ SANTOSH KIRAN.
djsantoshkiran is offline   Reply With Quote
Old   December 22, 2014, 03:51
Colinda
colinda1 is on a distinguished road
Dear DJ Santosh Kiran,
Maybe you can describe your problem such that people with experience in HEXPRESS/View can help you?
Best regards,
Colinda.
colinda1 is offline   Reply With Quote
Old   September 2, 2017, 22:00
Can
Lazarus is on a distinguished road
Dear friends,
I am trying to carry out a grid independence study with 3 different mesh size using HEXPRESS. I want to set the grid refinement ratio(r) to 1.4.
My question is; should we apply this value(r) only for Initial Mesh step at the beginning and keep the other parameters same? However, when i applied this refinement ratio for only in Initial Mesh step, the difference between medium and fine grid counts is very small, i.e medium count is 2M and fine is 2.7M. Is it also necessary to change the refinement values ​​on the surfaces and curves? How can i ensure that the grid refinement ratio will strongly enforced in the x, y, z direction as we move from the coarse to the medium, or from medium to fine? Can you help me if you have any knowledge or experience about this issue?
Any help will be greatly appreciated.
Lazarus is offline   Reply With Quote
Old   October 3, 2017, 04:54
Default Grid independence study
  #33
CFDUser
CFDUser12 is on a distinguished road
Hey Lazarus
As you might have read in the paper from Tokyo Workshop 2015 NUMECA recommends to perform grid dependence studies based on changing the initial cell sizes. This allows to refine the whole fluid volume and not only the areas right next to the solid. Hexpress defines the initial mesh as an integer number of divisions in each direction. That is why the refinement ratio 1.25 is ideal, because it allows to keep integer number of cells (6, 8, 10 for example).
In practice:
- Medium mesh: the initial mesh needs to have a number of cells in each direction that is multiple of 4. For example, 20 cells in X direction, 8 cells in Y direction, 8 cells in Z direction. Try to keep the initial mesh as isotropic as possible, the default proposed by Hexpress is isotropic.
- N coarse = 3/4*N medium, N fine = 5/4*N medium, where N is the initial number of cells in X, Y and Z directions. If you need more meshes just continue with the same ratio.
- The diffusion (Adapt to geometry > Global > Advanced > Refinement diffusion) needs to be 1 for coarse, 2 for medium and 3 for fine. This diffusion is a measure of how far from the solid surface the refinement propagates in number of initial cells. The reason to change the diffusion is to ensure the distance covered by refinement is the same in all meshes.
- All surface refinements need to be defined with a defined "Max nb of refinements" and "target cell size" = (0,0,0) --> this way the different initial meshes will lead to different mesh sizes.
Thanks
CFDUser12 is offline   Reply With Quote
Old   April 21, 2018, 04:16
mmolaei is on a distinguished road
Dear guys;
I have some problems in using hexpress/hybrid for generating mesh inside a geometry with interior zero-thickness walls. could you please help me in this regard?
Bests,
mmolaei is offline   Reply With Quote
Dynamic Mesh Problem. Tom Clark FLUENT 10 June 21, 2021 05:27
[ICEM] Hexa Mesh Smoothing Jules ANSYS Meshing & Geometry 6 December 4, 2010 19:00
basic of mesh refinement arya CFX 4 June 19, 2007 13:21
Numeca Hexpress and Fluent V6.2 Saif-Deen Akanni FLUENT 0 October 18, 2006 13:36
General questions on grid-based computing Adrin Gharakhani Main CFD Forum 21 June 5, 2000 14:47
