Home > Forums > Software User Forums > Fidelity CFD
History Convergence: Graphical problem
Old   March 17, 2010, 14:04
Default History Convergence: Graphical problem
Quentin
Bedotto is on a distinguished road
Hi all,
I'm working with fine/turbo 8.6-1 on turbomachinery. I've launched a calculation with 1500 iterations. With Monitor I've plotted my history convergence curve and I've seen the calculation required more iterations in order to attain convergence.
In order to continue the calculation I've avoided to delete the history convergence and I launched the calculation from the previous run file.
Here comes my problem. When I launch Monitor to check the history convergence curve I obtain graphical bugs and a amount of lines but there is no more curves.....And it's clearly a graphical problem (i've already checked if it wasn't a divergence).
I would like to know if it's a known issue or did i make something wrong? I hope that someone could bring me some elements to solve this annoying problem.
Thanks
Quentin Bedotto
Bedotto is offline   Reply With Quote
Old   March 18, 2010, 00:40
Hamid Zoka
Hamidzoka is on a distinguished road
hi Bedotto;
what do you mean by "amount of lines but there is no more curves" ?
can you clearly describe it?
what about history of convergence curve inside the FINE? deos it have a simliar behavoir to what MONITOR shows? or it is normal?
can you see the convergence curve in FINE when you restart the calculations? is it updated as the iterative solution goes on?
FINE and MONITOR convergence curves should show an identical trend.
check this and come back again.
Hamidzoka is offline   Reply With Quote
bug, history
convergence problem commonyue Main CFD Forum 1 December 1, 2009 04:54
Submerged fin, Convergence problem supermouniette FLUENT 10 July 6, 2009 11:47
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 02:17
3D Fluid Flow Convergence problem Emily FLUENT 2 March 21, 2007 23:18
Non Convergence of 3D Heat transfer cfd problem Balraj Main CFD Forum 3 December 9, 2004 01:24
