December 30, 2009, 05:36 |
system error
In AutoGrid5,after Finish generating 3D Mesh,When I press the "save project"buton,it always come up "system error ,Emergency save mesh in .recover.igg" Sometimes ,very nearly Finish generating 3D Mesh,it comes up as above related?
who can tell me why?How to modify it? many thanks! My soft is 8.7. |
March 13, 2010, 02:37 |
Hamid Zoka
Rep Power: 19 |
it may be concerned with number of meshes you use. what is the number of meshes? how much is your RAM? do you see this error each time you mesh or not? reduce you mesh number and check if this error appears.
check and reply. i will comback to you. regards |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 12:39 |
OpenFOAM15 paraFoam bug | koen | OpenFOAM Bugs | 19 | June 30, 2009 11:46 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 21:30 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 18:38 |
a question of open ".cas" and ".dat" files | fanzhong Meng | FLUENT | 4 | May 15, 2006 12:40 |
