Home > Forums > Software User Forums > Fidelity CFD
Autogrid: discontinuity of 90 degrees in shroud
Old   January 26, 2009, 10:15
Default Autogrid: discontinuity of 90 degrees in shroud
Eric Joubarne
Hi, I'm new to AutoGrid and I have the following error message:
"Discontinuity of 90 degrees in shroud"
Here is what I do: 1- I have my CAD geometry in the IGES format and I click on "import and link CAD". 2- I select the 7 small curves that are defining the shourd and I right click on "link to shourd". I have no error message so far. 3- Then I select the 8 small curves that are defining my hub and I right clik on "link to hub". At this time, the error message displays: discontinuity of 90 degrees in the shourd.
Does anyone have an answer ?
Eric Joubarne
Old   July 21, 2009, 05:34
deng qingfeng
afeng0796 is on a distinguished road
Dear Eric,
It may be surface,or the curves must be a entity,and the orientation must be right
afeng0796 is offline   Reply With Quote
specifying tip clearance at the shroud Mohammad CFX 1 December 25, 2008 08:06
Hub-to-Shroud Diagramm Arianna CFX 0 April 17, 2007 12:01
About the using of AutoGrid 5 Wheeler Fidelity CFD 0 November 5, 2005 08:05
Autogrid ked Fidelity CFD 1 August 19, 2003 11:36
how to decide the shroud and hub line angel Fidelity CFD 4 April 1, 2003 03:39
