Home > Forums > Software User Forums > Fidelity CFD
Boundary conditions for rotating fan
Old   July 21, 2008, 03:34
Default Boundary conditions for rotating fan
rohit
I want to know, which type of boundary conditions should be given to rotating machines case? (turbomachine). I want to simulate a cooling fan, and I want to predict performance curve then which type of boundary conditions should I chose?
Old   July 21, 2008, 13:21
Default Re: Boundary conditions for rotating fan
recoba
i don't know
Old   August 8, 2008, 04:47
Lily
Dear rohit What kine of cooling fan you want to simulate?
In our laboratory, we use FINE/TURBO to simulate the performance of CPU fans.
You can set the boundary conditions Inlet: mass flow Outlet: static perssure
I hope this can solve your problem
Best regards,
Lily
Old   September 24, 2008, 08:18
Zhigang Liu
I think you should define the boundary conditions like this: Inlet:Total temperature and total pressure Outlet:Massflow and static pressure(reference) Periodic Solid:rotation speed rot
Further more,i think The injector shuold also be defined
Boundary conditions for rotating fan rohit Siemens 3 October 4, 2008 05:18
Boundary conditions for rotating fan rohit FLUENT 5 July 24, 2008 01:26
Boundary conditions for rotating fan rohit CFX 2 July 22, 2008 10:20
Boundary conditions for rotating fan rohit Main CFD Forum 0 July 21, 2008 06:45
Boundary conditions for rotating fan rohit Main CFD Forum 0 July 21, 2008 03:31
