Home > Forums > Software User Forums > Fidelity CFD
propeller blade meshing
Old   December 6, 2007, 08:45
Default propeller blade meshing
Terence
I'm trying to make a structured mesh with IGG on a propeller blade but I've got problems of overlapping cells and I don't know why. When I just make a face grid patched on one surface (pressure or suction side) of the blade (twisted blade), IGG shows me a lot of overlapping cells which are not visible on the face grid? What's the problem?
Thanks for your answers
Terence
Old   December 15, 2007, 21:57
Default Re: propeller blade meshing
Eddy
Dear Terence:
There maybe several possibilities. Maybe your first cell distance is too small. Maybe the grid cells near leading edge or trailing edge need to adjust the direction. Maybe the grid faces get to twisted, you can change the grid style to O-mesh or J-mesh.
Why not use the Autogrid software to make grids? I think it's easier and convinient than Igg for propeller meshing.
Old   January 17, 2008, 01:46
Samuel
Hi Terrance,
I would like to know as to whether you are working in an industry or research.
Sam
Old   January 18, 2008, 04:05
Terence
Dear Eddy,
Thank you for your answer. In fact the propeller blade is twisted and so are the grid faces on the blade. But even if grid faces get to twisted they visually clearly don't seem to overlap. Until now I have neglected these overlapping cells because my grid quality is quite good and I have launched some computations which have converged. Is it possible to obtain convergence with overlapping cells anf if so, will I obtain erroneous results (I don't have the good results but they are not too far from the right solution and I can't know if it is due to these overlapping cells) ?
I am also trying to use the Autogrid software but I have some problems to define the geometry. I am working on it.
Thank you again
Terence
Old   January 18, 2008, 04:08
Terence
Hi Sam,
I am working in research at Université Libre in Brussel.
Terence
Old   January 18, 2008, 15:23
Samuel
Hey Terrance,
Have you heard about GridPro?Are you aware of the capabilities of GridPro and the quality grids which it can provide?
Sam
Old   January 20, 2008, 10:36
Terence
No I haven't heard about GridPro...But now I have spent time on numeca softwares so I would like to continue for a moment.
Old   January 21, 2008, 00:39
Samuel
Thats fine Terence,if you feel there is some need for a Good quality mesh,then you can think about trying GridPro.
Old   July 15, 2008, 14:31
Aji
Dear Terence,
You can use propeller/wind turbine wizard that is now available in version AutoGrid5 8.4-1.
It's automatic and provide high quality mesh. The topology is automatically adapted to twisted blade.
Regards,
Aji
3d meshing strategy for propeller in gambit Harikrishna FLUENT 3 January 12, 2012 07:38
meshing fan blade in tunnel... fadly CFX 4 August 10, 2007 17:52
Blade thickness on propeller wash prediction Lam Main CFD Forum 1 October 28, 2005 03:36
Gambit & Propeller Meshing James Date FLUENT 7 July 6, 2004 17:54
Meshing a Propeller K.C CFX 1 October 22, 2003 19:20
