Home > Forums > Software User Forums > Fidelity CFD
what is isentropic mach number?
Old   August 15, 2007, 01:56
Default what is isentropic mach number?
peck110
many thanks for the one who answer me!
Old   August 16, 2007, 05:19
Default Re: what is isentropic mach number?
Jonas Larsson
I wrote a bit about this in CFD-Wiki here:
http://www.cfd-online.com/Wiki/Isentropic_Mach_number
Old   March 16, 2008, 02:10
SA
how to calculate the isentropic mach number for rotating compressor blade. should that formulation be the same or we must replace the total pressure with relative total pressure
Old   July 8, 2008, 04:15
Vinayender
I guess if we take relative P0_freestream then what we get is relative ISentropic Mach no silmilarly if we take absulote P0_freestream then what we get is absolute Isentropic Mach no. Again I guess in turbomachinary people always want relative isentropic mach no so better use relative P0_Freestream.
Any how, thanks a lot Jonas for your definition of Isentropic Mach no for which i was searching for. Also thanks Peck for asking that question.
Thanks, Vinayender.
Old   July 8, 2008, 06:37
SA
should we take Po at inlet or outlet? should we take the Po at inlet for both turbines and compressors.
Thanks a lot
Old   July 8, 2008, 07:50
Vinayender
We should take P0 at Inlet but not outlet because at oulet P0 might have got reduced because of losses.
It should be Inlet for both Compressor and Turbine (and your inlet can be at bottom or at top in meridonal view depending wether it is a compressor or turbine respectively).
Thanks, Vinayender.
Old   July 9, 2008, 14:18
SA
Dear Vinayeder, Thanks for your nice reply: I have some confusions about this "It should be Inlet for both Compressor and Turbine (and your inlet can be at bottom or at top in meridonal view depending wether it is a compressor or turbine respectively)"
can you eloborate more. should I average pitchwise at two locations for compressor and turbine respectively?
what if I am only computing flow in rotor with uniform flow at inlet?
Thanks.
Old   November 15, 2021, 21:58
XX
gjtmawa is on a distinguished road
Originally Posted by Jonas Larsson
;157867
there is another definition of isentropic mach number using rothaphy
gjtmawa is offline   Reply With Quote
Mach number sean Main CFD Forum 1 January 29, 2009 14:13
how to plot relative isentropic mach no around bla sa FLUENT 0 April 14, 2008 20:37
Mach number 30 !!! VVJ CFX 7 March 17, 2008 21:52
Abt: Mach number.. Help! Plz! jinwon park Main CFD Forum 0 February 5, 2008 14:57
mach number Akbar FLUENT 1 June 24, 2005 04:08
