Home > Forums > Software User Forums > Fidelity CFD
Help for Autoblade Fitting
Old   April 27, 2006, 00:04
Default Help for Autoblade Fitting
stewart
Hi,everyone.
Now i'm optimizing a centrifugal compressor whose blade with both leading and trailing blunt edge. When i procees Autoblade_Fitting, the software prompts me that "no intersection between target suction side and a stream surface". I know that there are no commom points at the leading and trailing edge. How can i write the geomturbo file? I want to fit the blade profile with both leading and trailing blunt edge.
Who know the geomturbo file format? Any help will be welcome.
Old   April 27, 2006, 00:14
Default Re: Help for Autoblade Fitting
stewart
Now the format of my geomTurbo file is as follows:
GEOMETRY TURBO VERSION 3.7
geometric_tolerance 1e-006
blade_expansion_factor_hub 0.03
blade_expansion_factor_shroud 0.03
blade_merging 0
units 1
number_of_blades 11
data_reduction 0
data_reduction_spacing_tolerance 0.0001
data_reduction_angle_tolerance 90
hub
ZR
31
-0.02 0.02687
shroud
ZR
31
-0.02 0.10304
suction
SECTIONAL
2
# section 1
XYZ
23
0.0273 0.01244 0
# section 2
XYZ
23
0.09234 0.04563 0
pressure
SECTIONAL
2
# section 1
XYZ
23
0.02628 0.01448 0
# section 2
XYZ
23
0.09157 0.04715 0
Old   August 18, 2006, 03:43
Colinda Francke
AutoBlade works with the intersection of the 3D blade surface with the surfaces of revolution defined by the flow paths (stream surfaces). The warning you have indicates that for one or several of the flow paths you do not have an intersection. Extending the 3D blade definition or redefining the flow paths can solve this.
Old   June 13, 2012, 09:07
Default problem
majid
majid2792 is on a distinguished road
i have this problem with autoblade too, can you solve it? if you find the problem please help me immidiatly?
majid2792 is offline   Reply With Quote
Old   June 14, 2012, 03:32
Hamid Zoka
Hamidzoka is on a distinguished road
you need to increase the following parameters in your ".geomturbo" file until the airfoil fully intersects with hub and shroud curves:
current values seem to be 0.03. Try bigger values.
Regards
Hamidzoka is offline   Reply With Quote
Old   June 14, 2012, 03:51
majid
thank you hamid for your answer
but I dont found exactly what i do
increase my flow path?
or increase my section in geom turbo?
Old   June 15, 2012, 10:40
Hamid Zoka
Dear Majid;
you can increase the span of blades manually through the ".geomturo" file.
if you pay a look at the geomturbo file presented by Stewart, both "blade_expansion_factor_hub" and "blade_expansion_factor_shroud" parameters are set to 0.03. it means that the generated blade should extend from both sides to 0.03m. So, you can easily change these parameters until they intersect with hub and shroud curves.
another way to do this is to extend the blade height directly from Autogrid.
depending on your Autogrid version (i.e. 4 or 5) the method is slightly different.
Old   June 26, 2012, 02:55
majid
Dear hamid
I do it but I have this problem too, Do you have another suggestion؟
best regard
Old   June 26, 2012, 03:10
majid
My error is:
''No intersection between target suction side and a stream surface.''
computation of the intersection between the target blade and the stream surfaces of the parametric geometry.
Old   June 26, 2012, 06:16
Hamid Zoka
try "exchange suction and pressure" prior fitting process.
Old   June 26, 2012, 09:01
majid
I try but i have problem too
Dear hamid, what file can be set in import target geometry file?
the geomturbo file?
Old   June 26, 2012, 23:50
Hamid Zoka
Yes, the tagret file is the "geomturbo" file. would you send me your file?
Old   June 27, 2012, 04:12
majid
ok
can you give me youre email?
Old   June 28, 2012, 05:20
Hamid Zoka
hamid.zoka@gmail.com
Old   July 1, 2012, 01:13
Hamid Zoka
Majid;
You need to study Numeca manuals carefully!
I 've reviewed your ".geomturbo" file and following tips come to my mind:
-you have assigned suction curves to pressure side and vice versa. you should fix it. simply change the suction curves with the pressure ones.
-when you work with Numeca you had better to use SI units. your dimensions(i.e. XYZ and ZR points) are all in mm and this causes problem. if you simply set the scaling factor in Autoblade fitting medium to 0.001 the so called error disapears. you had better to set "data reduction" to 1.
but you may still see this error: "initialization failed" or something like that. to solve this problem I suggest you the following tip:
-before parametrizing your geometry in Autoblade fitting (Design 3D), you need to check if parametrization settings fitts to your blade. for example number of suction and pressure Bsplines control points and their stretching factor should be properly selected. Also the LE and TE parameters (Round or Blunt) and... . if not, you will have a blade with intersecting suction and pressure sides that is clearly useless.
this needs try and error and more substantial works!
One more question: What is the name of your professor?
Regards
Old   July 7, 2012, 09:01
majid
Thanks dear hamid
I try to solve it
Dr derakhshan
Originally Posted by Hamidzoka View Post
Majid;
Regards
Shock Fitting Craig FLUENT 1 April 24, 2008 18:06
AUTOGRID and AUTOBLADE strengths and limitations Haider Fidelity CFD 1 December 6, 2007 21:24
help:AUTOBLADE haider Fidelity CFD 3 July 2, 2007 03:25
Data Fitting Ramp Main CFD Forum 0 April 23, 2006 14:33
AutoBlade for airfoils?? Steve Fidelity CFD 2 August 4, 2003 10:45
