April 15, 2006, 05:15 |
cylinder, drag, onvergency
I have simulated the flow around a circular cylinder using the following configuration (steay, SPALART-ALLMARAS, C,H-MESH (the c-topology defines the inlet), Char. Rey-Number: 140000). But there occur several problems: 1. the convergence history (global residual) is fluctuating - it also happens with a laminar configuration or another turbulence model. 2. I applied the following boundary conditions: inlet=static quantities imposed (to define the velocity Vx=100 [m/s] and pressure 101300 [Pa]). OUTLET=static pressure impoed, SOLIDS WALLS=adiabatic, EXTERNALS=settings from the inlet. Do you principally agree with these settings 4. I would like to calculate the drag - a was thinking about F=m*a but I am not sure how to connect it with my problem. 5. The flow behind a cylinder is not steady - could you explain to me what will I have to do to make it unsteady (boundary condition, mesh generation) -- (I want no rotation!). Thanks. |
drag coefficient of cylinder | Avijit | FLUENT | 12 | April 23, 2017 04:26 |
Drag coefficient of cylinder | chenzhi | FLUENT | 1 | December 2, 2008 12:23 |
drag coefficient of cylinder | Libellen | FLUENT | 10 | August 29, 2008 22:56 |
drag on cylinder | dominique | Main CFD Forum | 1 | April 27, 2004 18:08 |
Cylinder Drag Data | Abuzar Abid | Main CFD Forum | 1 | September 5, 2000 08:37 |
