March 10, 2006, 04:46 |
Hexahedral or Tetrahedral
Hello! I am simulating an Inlet volute which has a blade ring at the end.
I am using ICEM and it is very easy to generate tretraheral meshes, but i have heard that using Hexahedral mesh would give better results. I would really appreciate if somebody could explain me how more accurate the hexahedral is and why, so I can make more effort to the hexahedral mesh. Thanks!!! |
March 22, 2006, 16:55 |
Re: Hexahedral or Tetrahedral
Dear Maria Angelica,
If you are planning to use NUMECA's software... I think you have no choice: mesh must be structured hexahedral (if using Fine/Turbo) or if you will use Fine/Hexa, then an unstructured hexahedral mesh is required. I think that NUMECA support team can help you better. I used ICEM three years ago, I did the effort of meshing with structured hexahedral blocks, but the ICEM 'automatic' tool to write the mesh in NUMECA's software format didn't work. So, I had to mesh the whole thing again with IGG... which, in my opinion, is more easy to use than ICEM, specially when dealing with structured hexahedral blocks for complex geometries... Good luck! Roque. PS. Do you speak spanish? |
April 4, 2006, 07:31 |
Hi Maria,
It is difficult to quantify how more accurate would be an hexahedral mesh. Comparisons between tetrahedral and hexahedral grids usually leads to following conclusions: - less cells are needed for an hexahedral mesh (that is certainly an advantage as you can then refine the mesh in some fluid zone for a same "budget") - convergence is better - prediction is said to be better (but this can be also a consequence of previous items). Hope it helps Regards, Remi |
February 19, 2007, 01:10 |
Hi all, Can anyone please share the code for generation of Hexahedral mesh or the source from where to get it!
Thanks Rani |
Tetrahedral vs. Hexahedral Meshing for CFD | Andy Bartels | Main CFD Forum | 16 | September 20, 2019 11:06 |
Tetrahedral and hexahedral mesh based on FVM | kuang | Main CFD Forum | 0 | July 20, 2008 05:52 |
tetrahedral or hexahedral? | rayy | FLUENT | 2 | April 9, 2007 06:29 |
7 Node Hexahedral Cells | Mark | FLUENT | 0 | February 5, 2007 12:10 |
hexahedral vs. tetrahedral cells | Christian | Main CFD Forum | 3 | March 21, 2006 07:41 |
