Home > Forums > Software User Forums > Fidelity CFD
About CFL number
Old   November 11, 2004, 01:18
Default About CFL number
yan
I am using fine/turbo to simulate a centrifugal pump. now i don't know what should be the best CFL number, and what's more, what should be imposed on the inlet and outlet conditions. A new comer thanks for your kind answer!
Old   November 13, 2004, 05:52
Default Re: About CFL number
SAM
Inlet conditions :
Total pressure Total temprature inlet flow angle
Outlet condtions
static pressure
clf number depends on convrgee firt try to simulate on defualt condtions. if solution is stable and converging then increase it other wise decrese
Old   November 14, 2004, 03:42
yan
Thank you!
Old   June 7, 2005, 02:37
BADRINATH
the best CFL number that you can use is the 0.75 as it has given best results for me when I was doing the similar problem
thanks and regards BADRINATH
Old   June 7, 2005, 05:05
yan
your problem is the incompressible case?
Old   January 1, 2006, 06:07
Default about inlet boundary condition
aniu
hello happy new year every one my english is so poor,genarary inlet boundary condition of steam turbine are all around the inlet ,now if we want to make partly inlet ,how to set in numeca ,i.e the degree is 0.5 thank you
CFL number Daniele CFX 5 July 19, 2012 20:11
[Fortran] (-real number)**(- or + real number) jinwon Main CFD Forum 3 June 14, 2007 15:50
Re Number mAx FLUENT 2 February 23, 2006 05:39
Ratio of Reynould Number and Froude Number CFD MAN Main CFD Forum 2 August 23, 2002 21:01
Low Ren Number KIAN FLUENT 1 February 29, 2000 06:54
