May 10, 2004, 03:32 |
about rotor 37
i am extremely disappointed that i still can't compute the rotor 37 with the low Re model (yang-shih).i even doubt about the new version of NUMECA. i try so many means but eventually i fail to make it go to convergence.can any person give me more guidence ?thank you !
June 2, 2004, 08:38 |
Re: about rotor 37
The rotor 37 test case is used to validate FINE/Turbo code and it is surprising that you can not run it to convergence. I guess the choice of parameters should be carefully checked. I would suggest that you take contact with NUMECA team to solve this out: info@numeca.be.
Did anybody run he ROTOR 67 by using CFX? | MouseInMilk | CFX | 0 | August 30, 2006 18:37 |
Rotor 37 | Max MIheev | Main CFD Forum | 1 | October 12, 2005 14:05 |
rotor 37 | sunshine | Fidelity CFD | 2 | October 1, 2004 04:29 |
Rotor 37 | sunshine | Fidelity CFD | 2 | April 12, 2004 09:58 |
rotor 37 | sunshine | Fidelity CFD | 0 | April 6, 2004 21:21 |
